PSI produced by the Airmatic compressor?
Old Feb 3, 2024 | 12:24 PM
1xsculler's Avatar
GLS450
What pressure should a good condition Airmatic compressor produce?
Old Feb 3, 2024 | 01:05 PM
eric_in_sd's Avatar
2007 GL450
Monitor the pressure sensor while the reservoir is filling and you'll get your answer.
Old Feb 3, 2024 | 02:09 PM
1xsculler's Avatar
GLS450
How to monitor pressure sensor?
Where could I read PSI?
Old Feb 3, 2024 | 05:02 PM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
Your scan tool should have it. Which one do you have?
Old Feb 3, 2024 | 06:07 PM
1xsculler's Avatar
GLS450
PSI
icarsoft MB ll is my scanner.
I have three pumps I want to check the condition/output of, i.e. two P-3277s, one brand new and one with an few hours on it and one Chinese Arnott, the number of which can’t remember which is about four years old.
I have set up a pressure gauge I can screw into the outlet.
Old Feb 3, 2024 | 09:32 PM
BlackML550's Avatar
The link below provides AMK website which has a downloadable document that specifies pressures and volume. MBWorld wouldn't let me add it as a document here for some reason. Scroll down that page a bit and you'll see "download"
https://amk-group.com/en/products/ai...nger-cars/lfk/
Old Feb 3, 2024 | 10:22 PM
Max Blast's Avatar
NGL450 w/EORP, S550
16 bar pressure in the central reservoir within 30 seconds.
Old Feb 4, 2024 | 08:44 AM
eric_in_sd's Avatar
2007 GL450
In the Airmatic section of your MBII scanner.
If you are confused because the reading is in bar, one bar equals about 15 psi.
I would not plug the output with a gauge to measure pressure. The pump will very quickly rise to its maximum and then do something, I don't know what, bleed off the excess via a relief valve? Simply pound away? Maybe do it with your Chinesium compressor, but I would not risk the valuable AMK compressors. This could well be destructive testing.
