Heated/Cooled cup holders
Old Jun 4, 2016 | 08:40 AM
dborleis's Avatar
2013 GL 450
Originally Posted by Dimitar Petrov
Hey I got the new wiring harness . It is almost done setting it up but there is a wire going in the arm rest compartment I can't figure out how to access it to unplug and plug new one seems like the light for the underarm rest compartment how did you do it ?!
Hi. I am facing the same issue. How did you unconnect that wire in armrest?
Old May 31, 2017 | 09:12 AM
f4i 954's Avatar
2009 e class 2012 ml350
I know its a hold thread, but was wondering if any one can elaborate on this?? what harness is needed and where does it plug in to if heated cup holder is retrofitted.
thanks
Old Oct 4, 2017 | 05:05 PM
CGohring's Avatar
'88 190E; '03 CLK350; '07 SL550; '10 GLK350; '13 ML550; '13 SL550; '17 GLE63s; '18 GT Roadster
instructions on removal of the center console
I found this somewhere, thought you might find it useful when trying to figure out how to unplug everything.
Old Feb 6, 2018 | 12:58 AM
thaiedwin's Avatar
2002,ML500
Hey everyone I wonder what do I need to retrofit this to my GL450.
1666804814 is the cup holder right?
What is this his wiring harness everyone is talking about?
Old Feb 6, 2018 | 09:31 AM
srfrboy's Avatar
2013 GL550 4Matic
https://www.shopmbonline.com/oem-par...-ha-1664405106
Old Feb 6, 2018 | 12:09 PM
DaveW68's Avatar
Veteran: Army
2015 S550
Getting the center console out is the easy part. There are a total of 6 screws that need to be removed (2 larger aluminum looking screws by the dash under the rubber cover where you can throw your keys, 2 larger aluminum looking screws in the center armrest under the rubber matting at the bottom of the cubbie hole, and 2 smaller screws in that cubbie hole that hold down the panel that has the USB and iPod connectors. Lift the iPod connector panel slightly until you can move it with the attached wires. Turn it until you can slide it through the hole. At this point you can easily lift the console to expose the 2 connections that need to be unplugged (large main connection & a smaller one with blue connector. Then you can easily remove it toward the back seat and take it out of the truck. It goes back in the same way it came out in reverse order. Taking it out and re-installing takes about 10 minutes each.
By far the most difficult part of the job is fitting the new wiring harness that contains the needed plug for the heated/cooled cup holder. It doesn't look to bad at first glance, but there are 2 wires that go through a hole toward the rear climate control and optional DVD player that cannot be accessed without removing the rear cover to get to the climate control and optional DVD player. Do not try to pry that back cover off as there are at least 6 screws holding it in place (2 by the 12 V power port, and 4 more that you can barely see when you lower the DVD player or empty binnacle. After all 6 screws are removed, you can unclip it from the top and pull the panel back where you will see the wiring harness holding the climate control panel on. After you unclip that wire, it should come out freely. (If you have a DVD player, then you also have to unclip that wire) Then you should see a couple of screws (IIRC) holding on a cover to the vent that air appears to flow through. You will need to remove those screws to remove the panel (it has foam) to be able to get the old wire harness out and the new one in. Connect the wires then reinstall the back cover in reverse order. It helps greatly to have a 2nd set of hands for that job as you'll need somebody to hold a flashlight to see the screws that need to be reinstalled. Torx screw drivers that have strong magnetism are very helpful in doing all of the reinstall. Otherwise you will need to tape the screws onto the screwdriver to get them started since you won't be able to get your fingers near those screws and those are very tight spots. The rest of the wire harness install is fairly straight forward. It's best to take some pictures of the old installed harness before removing it so that you can see how the new one installs and where to clip everything. The easiest part of the job is removing the old cup holder and installing the new one. That job can be done in 2 minutes. And don't forget to reinstall the Keyless Go antenna to the new harness. There is actually a wire on the new harness that is taped off that is used to plug that in (I think it is a brown & white wire with a black connector....but it is exactly the same as the one that is on the old harness that connected to the antenna. Untape that wire to free it up.
After all of the wires are connected, you can easily reinstall the center console into the truck and enjoy your new heated/cooled cup holders.
Old Feb 6, 2018 | 07:32 PM
  #32
black06c230's Avatar
mgLipGD
Great details on the swap, makes me really want to try this, course get my factory buddy who prob can do this blind folded.
Main question is since the new setup is 2 diff sizes for the cups can it still accommodate say 2 32oz cups from McDonald’s?
I realized when looking to buy ours they were each a diff size and figured they couldn’t each hold the same size cup so it dropped of the list if needed options. Plus Active Curve was a must have which already made a truck hard to located so couldn’t be too picky when 1 was found after 3-4mths of looking
Old Feb 6, 2018 | 09:33 PM
  #33
DaveW68's Avatar
Veteran: Army
2015 S550
Yes, two 32 oz cups from McD will fit. On the smaller side, the smaller, lower portion of the cup fits perfectly. On the larger side, then entire cup will drop down in the holder. I find these new cup holder more useful than the originals as drinks aren't moving around in them causing a possible spillage.
Old Feb 6, 2018 | 10:35 PM
  #34
srfrboy's Avatar
2013 GL550 4Matic
Dave, thank you so very much for the great detail on your step by step install. My parts are on order, and I will be calling you for help when they arrive.
Old Feb 7, 2018 | 12:10 AM
  #35
mgLipGD
thanks for the help, will add this to my list of items. Now to locate a piano black rollback set. Looks like missed a set on eBay a bit back.
Old Feb 7, 2018 | 11:12 AM
  #36
DC-BENZ's Avatar
GL350 Bluetec and GLS580
Wow, $560 for a cup holder!? Seems like a good idea if you can find one in a junkyard or ebay wrecker though. Here's a blowup..
Old Feb 7, 2018 | 11:30 AM
  #37
DaveW68's Avatar
Veteran: Army
2015 S550
If you can locate a heated/cooled cup holder with any type of cover, you'll be just fine as the cover from your existing unit is simple to swap over.
Old Feb 7, 2018 | 02:28 PM
  #38
thaiedwin's Avatar
2002,ML500
I believe the W166 ML /GLE heated cup holder is the same for our GL. Anyone have successfully installed the heated cup holder for the 2013 GL?
Old Feb 7, 2018 | 02:32 PM
  #39
DaveW68's Avatar
Veteran: Army
2015 S550
Yeah...me.
Old Feb 7, 2018 | 02:59 PM
  #40
DC-BENZ's Avatar
Ohh if that's the case there are tan and black examples on Ebay for ~$250.
Old Feb 7, 2018 | 06:44 PM
  #41
srfrboy's Avatar
2013 GL550 4Matic
Just got mine on Ebay for $200.00. Wiring harness was an additional cost that I bought from the MB parts website posted earlier in this thread.
Old Feb 7, 2018 | 10:44 PM
  #42
mgLipGD
Got mine too from eBay $111 shipped. Friend who works at the factory is sourcing me the needed harness from the factory. Total cost should be $111 plus some beer when he pulls it out and swaps it out pit stop style. When I text him I ordered the cup holders and needed his help he was like man i just got done pulling a console out!!
Keep all posted on this thread and my “Panda Build Thread”.
Thanks for all the details to make this a easy project.
Old Feb 7, 2018 | 10:51 PM
  #43
thaiedwin's Avatar
2002,ML500
How did you all get under 300 where all my search comes up to 500 plus?
Old Feb 8, 2018 | 12:11 AM
  #44
mgLipGD
i searches specifically for “mercedes heated cup holder”. Past ones have sold for $95-200. One I got was listed at $100 plus $11.xx shipping.
Old Feb 8, 2018 | 07:40 AM
  #45
srfrboy's Avatar
2013 GL550 4Matic
eBay item number: 263462881977
Old Feb 8, 2018 | 07:41 AM
  #46
srfrboy's Avatar
2013 GL550 4Matic
Thats a steal at $100 plus shipping.
Old Feb 27, 2018 | 10:22 PM
  #47
mgLipGD
My buddy just came by and installed mine. Will post up a few pics in the next few days. Installed pretty easy and didn’t use the mentioned wire harness as he works at the factory and had the wire diagram and was able to pin my existing harness. I have the wire diagram to post. Oh and a pic of the crazy expansive tool they use on harnesses.
Old Feb 28, 2018 | 11:16 AM
  #48
srfrboy's Avatar
2013 GL550 4Matic
Here is mine installed on my 2013 GL550
Old Feb 28, 2018 | 01:16 PM
  #49
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
The question is, do these really work? Like if you have a luke warm water bottle, will it cool it?
If you have a cup of coffee that is luke warm, will it make it hot again?
Old Feb 28, 2018 | 01:23 PM
  #50
Neurobit's Avatar
2021 GLE 53 AMG Coupe
Nope. They are meant to maintain a hot drink hot, or a cold drink cold. I use mine daily.
