Camera ineffective at night
I then checked with the dealership a few times after that and they said that all my software is “up-to-date”. Now that I found the code/version from this thread, I’ll be going back.
The first time my wife took it to the dealer they didn't apply it. I had to spell it out for them and send them the info in this thread. Thanks to all who helped get this sorted out.
eBay has the replacement License plate led lamp which is 6x brighter.
I also replaced the reverse bulb to 800lm led each.
I can see where I am backing up to now. Dealer say you can't replace these but it's doable.
Many thanks
The '15 GL550 we have is terrible, however, when I took it in and gave my service guy the service number he said it wasn't applicable for my car (I think he ran my VIN).
But it was done on your 2015 and improved it?
http://m.ebay.com/itm/271932201965?_trksid=p2057872.m2749.l2649&_mwBanner=1
There are two screws from the door handle and the rest are clips.
Careful not to break the clips or retainer. First time will take a lot of force. Try not to use your body weight, and only pull out 2-4 inch at a time until all clips are unclipped; otherwise, you may risk breaking something.
To remove the backup bulb, squeeze the white tab together and pull out .
I actually bought a broken tail lamp off eBay for $50; then realize how easy it was...
Here are the trim removal kit:
I got fed up with the dealer inability to fix 'stuff', so it was better for me to solve all these annoying issue myself.
I put those led posted above on my GL and smacked my service advisor in the face since he said those lights are not replaceable.
I have a 2014 GL 63. If your reverse light is halogen or yellowish, then you can replace it.
The license plate module is led and can be remove only by opening the trunk trim panel.
If you don't care for the current one, you can force it out but it will break the clip holding it in place.
Definite improvement in pitch black area where I previously can't even see the white parking lane marker to backup and reserve park the car properly.
I am in the Bay Area, if you want to see, it's cool to meet up or drop by
So, I took matters into my own hands and figured I would get the high power LED reverse lights. Two problems: It generates an system error in the display, and while they are brighter than the standard bulb it did not fix the issue. The reverse light window in the tail lamp assemble is very small so it has little effect on projecting enough light to make any difference. Sadly, it was a waste of money, it doesn't work.
This issue is specific to the 360 camera, as my wife has a 15 ML350 with the standard camera and it works great!
MB needs to find a fix!
This is noticeably worse than single camera systems in the previous gen or any other cars.
You might say that the system is practically useless at night.
Anyone else noticed this?
Thanks.
I installed two LED mini-projectors in the back of the SUV, wired to the trailer hitch wiring and bolted to the undercarriage. When I go into reverse, the lights go on, when I go out of reverse they turn off. The work was done by AfterFX of Stamford, CT. It took them only about 2 hours to install and costed me $799 - the outcome is marvelous.
