Low Coolant Level Warning...
It seems like the factory ships the trucks near the minimum fill level and then it takes a few thousand miles for the coolant to find its level within the system despite the fact the visual indicator remains within the normal range.
I bet you can have your dealer add a tiny amount and it will be fixed and you'll never have to worry about it again.
Oh well, I have the 10K service coming up so I will ask them the same.
lately i have noticed a slow leak (last time when the coolant pipe went bad the leak was quicker, i'd refill and next day it would be low again), the low indicator would come on every a few months and i have been topping it up. lately i have noticed small puddle (not a lot maybe a few drops) on my garage floor semi-regularly (seems like if i leave the car there long enough i will see some), under the the driver side front pumper. looking under the hood i can see some liquid pooled on the tray around there. took it to another indy but the guy said he pressure tested it and can't find the leak?
