Can't get Tires Balanced
Old Mar 6, 2016 | 08:33 PM
jw1977's Avatar
GL450
I replaced the stock Pirelli's at 22,000 miles. I purchased the same the Pirelli's but a weird problem has come up. Since I purchased them I can't get them balanced correctly. I think it's the rear tires as it it's something that you feel in the seat of your pants starting at 55mph. I've taken it back to the shop now 3 times, and each time they say that they weren't balanced and have fixed the problem. But the problem keeps coming back. What could the problem be? Could there be a problem with one of the tires being out of round or a problem with a belt inside the tire? What should I do? The tires have 3,000 miles on them now.
Old Mar 6, 2016 | 08:54 PM
jerome8283's Avatar
GLS450
When the problem reappears does it occur right away or during the first drive for the day? Do you drive the vehicle daily? Has your driving frequency changed? Did they try rotating the tires?
Old Mar 6, 2016 | 10:16 PM
aeggroup's Avatar
2025 Range Rover, 2022 BMW M850 , 2017 MB E400 Coupe
Check if your tire shop uses Hunter Road Force 9700 balancing machine. If not - use this link to find a shop, which has it and go there :
http://www.hunter.com/gsp9700
Old Mar 7, 2016 | 05:43 AM
JMCarter's Avatar
2013 GL350. BMW 335. 2014R1200RTW
Had exact same problem, despite road force balancing twice which involves dismounting the tires enough to get it rotated on the rim enough to try balancing again. Eventually gave up on them, Tire Rack got me a refund on them and Michelins solved the problem.
Old Mar 7, 2016 | 08:43 AM
mtm's Avatar
mtm
gl450
common problem with Pirelli Scorpion Verde on the GL450. My dealer tried to balance 3 sets before giving up and installing Bridgestone Dueler tires instead, which solved the problem.
I had exactly the same problem - vibration/shake coming on after 55-60 MPH
Old Mar 7, 2016 | 09:10 AM
yk0786's Avatar
2014 GL350
I had the Pirelli Scorpion Verde on my GL350. The worst tires I had purchased. The car felt unsafe while driving in the rain and had vibration/shaking coming on after 60MPH as well. I had to change them out at 22K. I now have the Michelin and the car is smooth and rock solid in rain again.
Old Apr 15, 2016 | 12:56 AM
SFML320's Avatar
2015 GL550, 2019 GLC350e
Same exact experience on the Scorpion but AFTER I installed a new set. The original set that came with the GL had no vibrations at all. After going through several balancing including the HUNTER - we all gave up and I too went with Michelins. The virbations are still there at highway speed but just not as bad as the replacement set of Scorpions. Hoping the next set of tires since they wear down after 20K miles will be better.
Old Apr 15, 2016 | 02:27 PM
SteveE400's Avatar
2015 E400 and 2015 GLK350
Have the tires checked for vertical run-out. There's a good chance that one (or more) of them is not really round. Had this happen on a set of Pirelli's many years ago, and haven't bought that brand since.
