2016 GL550 Right Front End Clunk - On Video
So I had mentioned this a few months ago, that the right front end had a suspension clunk. It actually started not too long after taking ownership of it brand new.
A few weeks ago I brought to the dealership to be checked. That day I drove it to the dealership though, it was quiet as a bell. They took the car and kept it overnight - and after having it for two-days, could not reproduce it. Although disappointed the GL didn't act up on their watch, I picked her up, and she was quiet as a bell. Crazy.
Anyway, just this week though, it started doing it again. And yesterday it was so loud it occurred to me that I could get this on video.
There are 2 clips below of the noise. When the noise starts in the right front, you can hear it clunk if you turn the steering wheel back-and-forth, and you can hear it on the right side of the truck over bumps.
Do any of you, have this issue, or may have an idea what it could be? I'm going to send these over to the dealership today so their forman can watch/listen to them.
Any ideas/advice would be helpful. I know the dealership will fix the issue - but they actually need to see/hear the issue first.
I recommend wearing headphones/or earbuds to listen.
I dropped the GL550 off at the dealership after sending them the videos. The foreman agreed there was something wrong. When I dropped it off, the SA also asked to listen to it in the vehicle, and now it can be reproduced at any time. It does get much louder the more you drive it, but even now just after starting her up, the noise is there.
They called me yesterday afternoon and said they think they pinpointed the issue and will need to keep the beast (her name is Brunhilda) for a few days to repair/road test it. The SA didn't say exactly what it is, but mentioned that there is a TSB on it. I personally think it's the right front wheel bearing. I'll know exactly what it is on Monday and will post the results.
It's interesting because when I drove to Canada from San Francisco in December (with 1,000 miles on the rig) there was this odd humming noise coming from the front right (I believe) that sounded exactly like a bad wheel bearing. That whoo, whoo, whoo sound. But that sound eventually went away after about 3,000 miles. And the dealership back then, when I got back from Canada, could not reproduce it.
I'll know more on Monday and will post the fix/results. I'm more curious than anything.
https://mbworld.org/forums/gl-class-...cornering.html
If you try to do some sharp turns maybe it will show up again?
There IS a TSB though that could be related to your issue and my issue, although it's rumbling noise coming from the front suspension, not a mechanical servo noise.
TSB LI32.34-P-058735
Xentry (mercedes): some vehicles experiencing from due to airmatic software not being up to date, the front axle has a rumbling noise caused by faulty threaded connections or play in bearings of link rods of stabilizer bar. Model 166.
Anyway, it obviously got worse (6,000 miles), to the point they were loose, as you can hear in the video, if you turn the steering wheel back and forth; the audible thump/clunk, as well as the clunks going over bumps. It wasn't normal and I'm so happy they fixed it. The rig is smooth as silk now, completely silent on the highway, absorbent over bumps.
They referred to TSB LI33.20-P-054920, removed both axles and bearings, cleaned specified surfaces, and applied grease to specified areas.
Made my day!!
I think this is the problem I have on my GL since it specified "turning corners". But my dealer can not hear it so I probably have to wait when it is as obvious as your one before I go to see them again(my car is 4000km now, so still a while to about 6000miles).
The GL drives so much better (feels/sounds like an S-Klasse now), and all this time, I've been missing out on what it's supposed to be like. And how the bearings were also causing so many other odd sounds in the front end. I really thought I had multiple issues.
I hope you find your issue too - you might want to bring up this TSB with the dealer.
Anyway, they called and said they couldn't reproduce it. Even got the "Our foreman is 200+ pounds and your seat is fine." The you must be crazy line. Anyway, I ended up fixing the seat myself with some aero-space grade grease. Simple fix that took all of five-minutes.
I guess the moral of the story is - go to a different dealership if you can. I took my GL to another dealership and they ended up fixing the issue. Yes, I had to "get it on video", but nonetheless, I think the dealership that I purchased the GL from, would have said, "It's working as designed" and would have done nothing.
Well, today while driving locally (no highway) to get a haircut, the front end clunking came back with a vengeance. Parked and moved the steering wheel back and forth and that noise is back and it is worse than ever. I'm so disappointed and don't know what to do at this point. I am going to call Mercedes NA on Monday - they need to deal with this. Not the dealer I've been going to - it's not their fault and I feel really bad about it.
I've been trying to figure this out on my own, maybe it's the front carrier assembly. It only happens when it's warmed up, and it sounds more like the axle or a steering assembly clunk - something is very loose there. If it's the carrier assembly ($3K part btw), it might explain the transmission clunking that resonates through the steering wheel, and the play in the transmission, that's really not good at all.
I gave up on the transmission complaint, which they said is normal, because I really don't want to be a PITA. But once the ugly steering wheel clunking was reproducible easily, they may need to check all areas that may have issues and come up with a solution. I feel bad about the whole situation.
The GL is going back in next Wed and after a conversation with the SA, he said they're concerned about it too, and they'll contact the manufacturer on next steps, which might be lemon/buy-back. I've already sent a letter to MBUSA as a precaution, since it's a required step by law to pursue the Lemon Law. I've heard zero from them. Not surprised actually. If the dealership cannot fix it this round, I'll formally get an attorney to handle the formal paperwork to start the process. And for the record, the dealership, has been amazing and best-in-class!
It's pains me that I have to do something like this - I really want "this" truck fixed, I love my GL and bought it because I love it. I love the color, the interior, the options, and the looks. I can't get an exact replacement because of the new GLS. I don't want a new GLS, I just want my car fixed.
