Check Engine Light
Old May 16, 2016 | 06:27 PM
NLYTN's Avatar
'13 GL450
Check Engine Light
So i noticed the check engine light just came on so i pulled over and opened the hood. This is what I found. Its the soft air intake tube/hose.Can anyone tell me what the correct name for this piece is so i can replace?
Old May 16, 2016 | 11:50 PM
Count Laszlo's Avatar
'16 GL550, '12 C350
I'm not 100% sure (best to call the dealership), but it looks to be the air inlet duct.
#9 Part Number: 2780902582
$97.00 USD from dealer
$77.60 online
www.getmercedesparts.com
Old Dec 31, 2018 | 12:47 AM
maneesh's Avatar
2013 GL450, 2023 Tesla Model Y LR, 2024 Outback L XT
bringing up an old tread. Now my dealer has replaced this once for me under warranty. It is broken again, or I should say, the soft black part has ripped like paper. Getting another one will lead to the same issue I think. These air intake pipes are designed poorly.
Wondering if there is any other option? Can I use flex tape or aluminum tape that is used for HVAC inside homes? How about bathroom fan vent pipe. They have a metal ring that could be bent to fit inside the oblong side as well as the circular side.
Any thoughts?
Old Jan 1, 2019 | 10:45 PM
chsu74's Avatar
GL 450, 993TT, Cayenne Diesel, 964C4
https://mbworld.org/forums/gl-class-...ntake-arm.html
Old Jan 3, 2019 | 02:43 PM
WinterPark321's Avatar
2009 E550, 2011 GL550, 2013 GL550
I wouldn't use any aftermarket made intake hose or try to duct tape it up. I would replace it as I think the manufacturers and "engineers" designed this way for extra air to be sucked in through the perforated cloth on the hose.
Old Jan 4, 2019 | 12:05 PM
chsu74's Avatar
LOL. Why would hot air from engine bay provide better performance in a turbo motor than cooler air from outside?
Old Jan 4, 2019 | 12:07 PM
Lol don’t ask me. These are the same ppl who made my “door locks” that don’t lock 😂😂
Old Jan 13, 2019 | 02:15 PM
Travisc77's Avatar
Soon to be 2013 GL450
Same issue here, when I saw your thread I checked mine and sure enough the drivers side intake was tore in two spots, for who knows how long. I put blue tape around both spots to at least keep the intake intact until the part comes in.
Appreciate the post.
Travis
Old Jun 24, 2024 | 06:32 PM
L Redmond's Avatar
CLS550
Did it fix your check engine light issue?
Travis
Old Jun 25, 2024 | 11:29 AM
thtguy's Avatar
2017 GLS 550
on my E63 the previous owner was a pilot and an A&P certified Mechanic, he fashioned new ducts from aircraft ducting... that stuff was indestructible compared to what Mercedes uses... I believe I will try to do that if the ducts on my GLS ever deteriorate.
Old Jun 25, 2024 | 10:12 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
The intake hose MB uses are almost as bad as wet toilet paper. Really low quality but I bet it was cheap to make.
Old Jun 27, 2024 | 11:38 AM
RollTideW163's Avatar
2014 GL450, 2006 S500, 2003 ML350, 1996 C280 (Prev 1995 C220, 2002 CLK320, 1980 300SD Turbo)
Don't mistake engineering designs from Benz in the good years, to Benz now.
Previously, it was designed "for a reason" and because it was trying to be quality.
Now, so many parts are clearly designed to fail, to offset margin pressure from regulations in the EU and also to encourage owners to just trade it in for a new lease. Another example of this is the brittle, plastic turbo coolant lines (that just turn to plastic conveniently as they approach the engine block with all its heat) - absolutely no good reason to do this and not to mention a very tedious repair with the engine in the vehicle. These are not accidents or good intentions.
