Torn air duct (intake arm)
I just noticed the intake arm is torn (driver side), in sure this is affecting some performance. Not sure if this is a common issue but 2 other used GL450's (2013 and 2015) I previously saw also had the same tear.
Besides dealer replacements, are there any options for upgraded aftermarket "cold air" style intake at ducts?
Thanks in advance!
Now if I can just find out about the charging system situation. Voltage ranges from 12.5-14.9 during operation. Dealership says its normal, but I've never seen a car that intermittently charges.
There was an owner who made their own out of off the shelf plastics auto tubing and couplers. I bought all the parts the too but haven’t done the swap. It looked like stock and easy to do. I will see what I can find and post back
**EDIT**
Found the info.
you will need 2 of these
https://www.spectreperformance.com/s...aspx?prod=8741
Which you can find at any Autozone, O'riellys and Amazon. Only other thing I used was Zip ties. You can do that or clamps. I have now actually separated the factory Mesh breather tubes from the plastic and use the Plastic tubes (that attach to intake boxes). This makes it easier to take on and off. You will need to cut the tubes that you buy to fit. If you try using the factory plastic combined with the tubes you may only need one tube cut in half.
**EDIT**
Found the info.
**EDIT**
Found the info.
Ordered mine (GL63) for $90 on eBay (driver side only). Online prices were the same as the charge $10-$20 in shipping.
Have you noticed any reduced airflow? I feel as though the tubes are slightly smaller in diameter?
How long have you guys been running the tubes for? I am with you guys, I absolutely do not want to replace the intakes with another material one that rubs on the top of the hood and fails.
This part certainly isn't well designed.
