2013 cpo vibrate felt via seat abd steering wheel. Motor mount
Just bought a cpo one. We love the car. Absolutely nice to drive. But you feel it as a big suv when you turn at corners... have to be slow.When test drive, I felt a little bit the vibration from theseat, the center storage box, and sometime steering wheel. As it is a cpo one, i took the plunge and brought it home.
After checking some posts here that talking about engine mount being the issue, we brought it into the local dealer for checking. They said this time it is the motor mount. I checked other sites and this seems a common issue too .
Under warranty so I am not concerned too much and will report back if that fixes the issue.
My question is if this is really quality of mount issue as its only 3 year old. Or is it V8 engine shaking or something else that leads to mount issue so later we will need fix again when its out of cpo warranty few years down the road.
Any insights or thoughts?
The work order says the mount is weak that caused vib...
Very happy and now it drives and idles in mint condition...
But again my concern is that after 20-30k more miles would this come back or just the bad mounts happened to be on the car?
Anyway just bought two more yrs extended cpo so a few years to go....
I have this issue with my 2013 CPO since the day i got it. Thought it was related to wheels/tires not balanced - had it balanced but the issue persists.
Thanks,
Maneesh
I have read the entire thread on vibration issues, and i know that there could be many causes to it, but people should realize any vehicle with this wheel/tire combo will have some kind of vibration, its just physics. Just my .02 cents.
to the OP, i'm glad you were able to resolve the issue with the mounts.
Pay to play in this situation. The hydraulic mounts that give the smooth isolation, have a finite lifespan.
Best or nothing
1. There's a vibration we feel mostly in the seat. Ruled out full vs. low gas tank. Seems to go away when put in park - so not sure that would be the engine mount issue??? I have previously had a valve coil? replaced... so not sure if that's a clue.
The dealer had someone drive with me but because they didn't feel in it the steering wheel, they had me convinced it wasn't a problem.
2. I also get the vibration at about 70 mph that goes away at higher speeds. It happens with both my OEM wheels and winter wheels.
Highway vibration that's not tires (unless both sets need balancing) will be something else in the driveline, possibly a worn driveshaft coupler or bearing, have to have it checked.
