Trailer Brake Controller Mounting
As most GL owners know, there are plenty of questions surrounding the towing of trailers, trailer hitches, and brake controllers. I thought these pictures would help anyone that is considering adding a brake controller to their GL. I used a Tekonsha P3 and mounted it underneath my steering column. The wiring was fairly straight forward. If you reach to the far back of the steering column and feel underneath the plastic shroud, there is plenty of clearance for screws for mounting, and it does not interfere with the movement of the steering wheel. The P3 is within easy reach and sight when towing, and it easily detaches from the mount when not in use.
Hopefully this is helpful to a few of you out there.
Received 1,550 Likes
'21 AMG53 wDPP & ARC, 19 GLC300 - Former- 10&14 ML BlueTecs, 20 GLE450 E-ABC, 15 Cayenne D, 17 Macan
Here try this:
We installed per the attached instructions, but later switched to the Tekonsha RF (radio, wireless). We strap the controller to the center console, because it's closer and doesn't need to be solidly mounted to activate the accelerometer. The accelerometer is attached to the trailer itself.
amusa (03-14-2023)
We went RF because I don't like reaching for a control, because if you need the manual lever, you need it NOW. On the console, it's right at hand.
Also didn't want to drill holes, and I hadn't discovered the Industrial Strength Velcro.
I still have the pigtail, as in the above attachment, in case we want to pull somebody else's trailer.
I called Tekonsha and talked to one of their engineers, who said the RF is their best performer, saying that having the accelerometer on the trailer itself gives better control overall.
It's probably more a personal preference of where, and at what angle, you want the lever. Top or bottom, high or low, etc.
http://www.benzworld.org/forums/x164...ml#post5782281
I know the center console in second generation GL is different, but this could give others ideas on what to do.
I have bought the same RF controller but didn't installed it yet. Did you have any difficulties to pair controller box to the remote? I have read some people had a hard time doing this.
Thanks.
I had no problems. It paired immediately, first try. I just followed the directions and then drove off.
I assume this was a plug and play installation? My 09 GL 550 already has a seven pin connector at the rear of the vehicle so I assume this was all done under the drivers side dash?
Hi,
I am considering purchasing 2016 GLE 350 for towing a Lance trailer GVWR 5500 lbs. Dry weight 4000 lbs.
I have the stabilizing hitch on the trailer already.
The car I am looking at already has trailer hitch (So I assume it has wiring connector at the back).
I will check that when I look at the car.
Does GLE 350 come with 7 pin round trailer connector (X58/11) or 4 pin flat connector?
I want to get the break controller and can easily wire it up front (Tekonsha Prodigy P2 Eletric Trailer Brakes Module Box Controller).
It comes with wiring harness to connect to car wiring at front.
OR I could buy the RF controller listed above... Can someone give me link/part number for RF controller?
How does RF controller work? You still connect trailer connector to car's 7 pin connector? Then how does RF connector give break signal?
Thanks,
Robert
Thanks,
Robert
2023 EQB 350 & 2014 GL350
Hi,
Thanks,
Robert
Thanks,
Robert
While I'd suggest asking this in the GLE forum, there is enough similarity with the GL that I'd strongly suggest a couple items:
1) Verify that the vehicle you are looking at has the factory hitch and not an aftermarket one. The factory hitch is robust and has its wiring integrated into the factory harness. Also, it's not uncommon for owners to add aftermarket hitches to haul bike racks, etc., that may or may not have wiring.
2) Look closely at the tongue weight of your trailer and the limit for the GLE. Often this becomes more limiting that the GVWR.
3) Include the X166 GL/GLS in your search. Used, the prices are much closer than new between the GLS ands GLE. The standard air suspension on the X166 will keep the truck level even with lots of weight in the back.,
Hi Robert,
I ended up getting used GLE 350. It does have factory hitch and NOT after market. There is a 7 pin connector.
The tongue weight on trailer is 435 lbs.
Per 2016 GLE spec... Class III/IV, 2" Receiver. Rear. 5000 lb Gross Trailer Weight; 500 lb Tongue Weight; 6000 lbs. Weight Distributing; 600 lbs.
Looks like it should work.
