2014 GL450 LED Headlight Kits???
Old Jun 30, 2017 | 11:29 PM
nguy0138's Avatar
2014 GL 450
I am trying to upgrade the stock Halogen lights to LED but so far unsuccessful. I ordered the kit from OPT7 but didn't fit and returned. Tried to order again from XENONHIDS after verify with the tech, still doesn't fit and have to return. Just wondering if there is a LED kit out there to work?
Old Jul 1, 2017 | 02:05 PM
fabbrisd1's Avatar
A gaggle of MB's
I might suggest you reach out to AZN - a frequent contributor here..
Keep the beat !
Old Jul 2, 2017 | 09:41 AM
nguy0138's Avatar
2014 GL 450
Keep the beat !
How do I reach out to AZN? Thanks
Old Jul 2, 2017 | 10:08 AM
tate16t's Avatar
S550
http://www.aznoptics.com/
Old Jul 2, 2017 | 08:55 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
They will try to talk you out of the conversion to LED's on your main beams. The light output is just not good enough with the H7 projectors.
Old Feb 15, 2018 | 01:34 PM
VRJ's Avatar
VRJ
2016 GL450
Did you make the switch?
Did you follow through on your attempt? What did you end up doing?
Old Aug 12, 2020 | 05:26 PM
Shoop405's Avatar
GL 450
Just acquired a GL 450 and didn't realize the car didn't have Xenons until it was too late...Has anybody tried the GTR Lighting Ultra 2.0 LED? https://www.theretrofitsource.com/H7...2.0?quantity=1 They are $200 and supposed to be plug and play. Or does everyone still recommend Aznoptics Xenon Conversion kit?
Old Aug 12, 2020 | 06:19 PM
VRJ's Avatar
VRJ
2016 GL450
Replaced with Hylux/Morimoto HID System - H7 5500K kit
Had the same issue 2 years ago, replaced them with below, ==> much better visibilty since then...
Old Aug 12, 2020 | 06:34 PM
BlownV8's Avatar
This, even the sponsor on this forum who sells both will tell you to get the HID system over the LED.
Old Aug 12, 2020 | 08:47 PM
Shoop405's Avatar
GL 450
[QUOTE=BlownV8;8131267]This, even the sponsor on this forum who sells both will tell you to get the HID system over the LED.[/QUOTE
thank you for the info! How bad is the install? I’ve done it in an Audi Before.
Old Aug 12, 2020 | 08:48 PM
Shoop405's Avatar
GL 450
that’s great that you have 2 years! Where did you purchase. Did you install yourself?
Old Aug 12, 2020 | 09:17 PM
geniushanbiao's Avatar
2012 ML350 Bluetec, 2015 GL350 Bluetec
I have put in a pair of LED H7 set I bought from Amazon for about $40 or so and am pretty happy about them. They focus the same way as the stock halogen bulb so don't have any problem of glaring other drivers. The only issue is that the light color is more towards white while the original halogen is yellow-ish (5500-6000K vs ~3000K), so the white light is less penetrative when the weather is not very good. The LED set is even cheaper than some high-end halogen. Installation is almost no different than halogen just you need to buy another set of adapter (less than $10). I put the ballast into the headlight housing with no issue.
Old Aug 12, 2020 | 09:33 PM
Shoop405's Avatar
GL 450
what brand are they? Do you have any pictures? On a separate note. Has anyone had issues with condensation in the headlight. One of mine is very bad. I’m going to try and get the dealer to fix it. In the event they refuse, is it fixable or am I better off buying a new headlight off eBay?
Old Aug 12, 2020 | 10:16 PM
I installed this set on my GL.
https://www.amazon.com/gp/product/B07HQBWR5F/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B07HQBWR5F/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Also bought an Aukee set and installed on my ML.
https://www.amazon.com/gp/product/B07FRC77GX/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B07FRC77GX/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Both are claimed to be 10000Lm however I'm pretty sure they are not up to what they claim, but definitely more bright than the stock halogen ones. I also have another set of 12000Lm pair but it's obsolete now. I don't have any photo on my hand though but they are pretty common 6000K lights that color match with the DRL pretty well. I only replaced the low beam but wanted to also get the high beam replaced to match the color but am just too lazy to do it these days. I'm essentially not using the high beam at all.
If you have water on the inside of the headlight, that indicates a leakage somewhere. It might simply be the seal of the two headlight bulb access covers. If those two are good then take the assembly off and give it a careful inspection and seal the leak, plus use a hair dryer to completely dry the inside see if it works.
Condensation on the outside can be reduced by polish+wax. Wax can be replaced with any hydrophobic coating like rainx, basically to make the lens hydrophobic.Make sure your wax is compatible with headlight lens (essentially polycarbonate).
I replaced the pair on my ML with a used pair from Ebay. I bought them separately though. There are ton of them on Ebay that are missing a tab or something but you can still find a few with everything intact. You can also consider an upgrade if you have access to Star/Xentry to program it. The reason I replaced that pair was due to the excessive fading of the lens which was not fixable to me. (need to remove the lens and polish the inside as well so I don't want to mess up with that)
Old Aug 13, 2020 | 04:19 AM
iisnoopyii's Avatar
2014 GL450
I have 2014 GL450 and I have try many HID and LED wtih the adapter retainer.
I don't recommend HID because they can get really hot and I don't like to have a bulky ballast zip tie in the engine bay. I like to have a OEM look install.
I try to place the ballast inside the headlamp housing before because there is a lot room inside but I burn up all of them because there is no ventilation.
If I put ballast outside then I will need to drill hole on the cover cap which I really don't like so I give up on HID.
As for LED, I have try many different types of H7 LED bulb and they all need that special retainer clip. I have try super glue and JB weld the clip before but they all fail and they always fell out of the socket.
I believe I finally found the perfect bulb after 3 set of HID kits and at least 5 different types of H7 LED.
https://www.ebay.com/itm/Lasfit-H7-L...hfKSA2&vxp=mtr
I have no affiliation with Lasfit but this is the perfect LED kit, the bulk has the retainer clip build in and its a simple direct replacement and I have this bulb install on my car for almost a year so hot summer night or cold winter morning the bulbs perform perfectly.
Also Mercedes has a very sensitive CANBUS system to give bulb out error if voltage not correct but this LED kit has no error message so far.
The color temp is around 6000K so looks OEM not some crazy blue light.
Old Aug 13, 2020 | 07:18 PM
Shoop405's Avatar
GL 450
wow for $99 pucks plus $10 for the new adaptors it’s worth a shot. Thanks for your advice.
Old Aug 13, 2020 | 07:30 PM
iisnoopyii's Avatar
2014 GL450
You don’t need to buy the retainer clip, this LED already has it build in and that is why it’s so easy to sway the bulb.
Old Aug 14, 2020 | 07:57 PM
Shoop405's Avatar
GL 450
I bought a set and they arrive Tuesday!
Old Aug 15, 2020 | 09:11 AM
cadetdrivr's Avatar
2014 GL350
Thread drift: now that there are LEDs headlamps that are direct replacements has anybody found LED taillight bulbs that don't throw errors AND don't require a resistor in the circuit?
Old Aug 15, 2020 | 10:32 AM
Shoop405's Avatar
GL 450
yes curious as well. I figured out how to change the temperature of the interior lights. What about the bulbs. Will the switch to LED’s throw fault code? I bought some in amazon that arrive today. Another random question. Anyone change out worn out buttons on their dash?
Old Aug 15, 2020 | 10:49 AM
vivaitalia's Avatar
2013 GL450
likely newer bulbs with higher brightness since then ... but these are mine for 3 years (no errors, no problems, knock on tires):
Brake:
https://www.amazon.com/gp/product/B07DYRQCML/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B07DYRQCML/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Reverse:
https://www.amazon.com/gp/product/B01LX4FMD1/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B01LX4FMD1/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Fog:
https://www.amazon.com/gp/product/B0731456Q3/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B0731456Q3/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Old Aug 19, 2020 | 02:27 PM
cadetdrivr's Avatar
2014 GL350
Brake: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
They illuminate, but with errors on both sides.
Old Aug 19, 2020 | 08:25 PM
Shoop405's Avatar
GL 450
man what a difference!
Old Jan 28, 2021 | 11:59 PM
jorell's Avatar
GL 450
I just picked up at 2015 450 and browsing the forums for some options to replace the halogens. This one looks promising - just plug and play. How's it working out for you so far?
