LOWERED my GL with MBCANSOLUTIONS handheld module
Old Apr 8, 2018 | 01:16 AM
mdot949's Avatar
2016 C63S AMG
Lowered my family hauler (GL450) today with the same MBCANSOLUTIONS handheld module I used to lower my E43 in my previous post(https://mbworld.org/forums/e-class-w...ml#post7424783). The results were equally as good! I went pretty conservative at F: 1 3/4" R: 2" as to preserve ride quality. Although, I must say that the overall look has completely changed, especially because you don't see a lot of these lowered! (note: this is a separate handheld module then my E43, each module can only be used for one car.)
The unit makes it so that you can adjust the ride height to whatever you want in mm's. Highly customizable and takes less than 30 seconds to apply.
Ebay Listing: http://r.ebay.com/rerclJ
Old Apr 8, 2018 | 07:04 PM
srfrboy's Avatar
2013 GL550 4Matic
Like the look of your GL lowered. How many MM did you go down?
Old Apr 8, 2018 | 07:44 PM
Beachproducer's Avatar
Porsche 911 now
I just love the look that gives! So I'm curious what impact this has on the ride height raise/lower function in the car - - do you ever even use that or just leave the car low?
Thx
Old Apr 8, 2018 | 10:48 PM
mdot949's Avatar
2016 C63S AMG
In the photos the car is at Front -42mm Rear -50mm from stock. The ride quality was slightly compromised due to how heavy the car is, so I adjusted it to Front -32mm and Rear -40mm and the look remains similar and the ride quality is superb!
Old Apr 8, 2018 | 10:49 PM
mdot949's Avatar
2016 C63S AMG
Thx
Basically the module sets the new baseline height. So the raise and lower functions all work the same, but they start from the new baseline height that you set.
Old Apr 9, 2018 | 09:22 PM
ooklaa65's Avatar
2015 GL350
I got a jeep grand Cherokee Summit Eco Diesel that lower itself when I put it into park automatically. Then lifts itself up when the is in drive and speed increases.
This is something interesting as my parents have a hard time getting into the GL. I wouldn't want to lower then while driving but in park to get in and out of is a different question. Maybe ill ask the software designed if he can incorporate this into a patch.
by the way his ebay listing say or best offer, did you get it any cheaper then what he list it for?
Old May 22, 2018 | 01:27 PM
relaxhero's Avatar
Mercedes-Benz
Lightbulb New store on AMAZON
Old May 26, 2018 | 12:21 AM
mercup's Avatar
How low will it allow the GL to go? I have a Yakima cargo box and wondering if I can use this to get in and out of the garage with cargo box attached...I need to be able to lower it by about 70mm to get it in the garage.
Old Feb 25, 2019 | 10:51 AM
Mark3133's Avatar
cl55
I'm going to buy the module on eBay to lower my gl350. Does lowering the vehicle cause any problems down the line for the car as In more wear on the suspension? I plan to keep this car for the long term and don't want to have trouble down the line to obtain a sportier look. Should I get a wheel alignment after lowering it?
Old Feb 25, 2019 | 12:04 PM
vivaitalia's Avatar
2013 GL450
Curious ... what compromised ride are peeps talking about? could you share details? ... I reasoned that lowering it would made the ride more "comfortable" ... lower wind drag, more stability being lower to the ground ... also, the eBay link has expired, does anyone have more details on this module? Thank You
Old Feb 25, 2019 | 01:13 PM
Mark3133's Avatar
cl55
https://rover.ebay.com/rover/0/0/0?m...2F282847463816
Old Mar 25, 2019 | 09:05 PM
tjbrum's Avatar
mdot..,
Still happy with the module?
Old Mar 26, 2019 | 07:45 PM
mercup's Avatar
Bought mine several months ago. It is a very simply product isn't very much to like or dislike...it does exactly what it says so that part I like.
Originally Posted by tjbrum
mdot..,
Old Mar 26, 2019 | 09:52 PM
mdot949's Avatar
2016 C63S AMG
mdot..,
Yup! It actually doesn't get used much once you dial in the exact height that you want. I keep it in the glove box for any future adjustments.
Old Mar 29, 2019 | 12:35 AM
tjbrum's Avatar
Great. just ordered. thanks for your input.
Old Sep 18, 2020 | 01:54 PM
jonUF02's Avatar
2015 GL550 4matic
I can't find anything for MBCANSOLUTIONS on Ebay right now. Can someone post a link that won't expire?
Old Sep 18, 2020 | 05:20 PM
Golfather's Avatar
GLS350d V6 AMG Line G-Tronic
try this:
Amazon Amazon
Old Sep 28, 2020 | 02:41 AM
Golfather's Avatar
Looking for a reliable seller of the lowering module that is active. Thanks.
Old Sep 28, 2020 | 12:18 PM
serb's Avatar
2017 GLS 450,Bmw Z4 35i
Can it make it high all the time,i dont like when it lowers all the time
Old Oct 2, 2020 | 09:28 AM
Golfather's Avatar
You can set it to whatever height you desire and leave it there for as long as you want. I think the range is +40mm to -70mm.
FYI, I found a supplier in Belarus who sells them if anyone would like the link to his ebay listing.
Old Oct 5, 2020 | 03:04 PM
Golfather's Avatar
Originally Posted by Egor63s
https://www.amazon.com/dp/B07C7G3J13
Waiting for your messege my friend !
Is that you sir??!
