Will the GL63/ GLS63 Brake kit Fit behind GL450/ GLS450 20 inch wheels?
Old May 30, 2018 | 05:33 PM
KAHBOOM's Avatar
GL450, AMG C63S Coupe
I did a search but did not see the answer. I am looking to boost the braking power of our 2015 GL450 (X166).
I am wondering if the 2015 GL63's rotors/ calipers will fit behind the GL450's 20 inch wheels.
Has anyone installed them on their GL?
Old May 31, 2018 | 10:12 AM
NaviTimer1's Avatar
GL550
I'm also intrested in doing this upgrade. I wonder how much weight this would add.
Old Jun 4, 2018 | 09:06 AM
rallycobra's Avatar
335XI
I don't understand why you need to increase the 'braking power'. Will your truck not lock its wheels and get into the ABS? If not there might be something wrong with the master cylinder or booster. I would flush the brake fluid and consider upgrading the pad compound before upgrading calipers and rotors, it's not a track car.
Old Jun 4, 2018 | 09:56 AM
KAHBOOM's Avatar
The thread topic is simple, so no need to derail the thread.
Are you sincerely asking, or are your questions rhetorical? It's obvious that the vehicle is not a track car. Were you otherwise attempting to educate me? And are you saying that the GLS63 is a track car since it has upgraded calipers and rotors? I am not seeing your logic in that statement.
If you help me understand your need to understand then I will help you understand my "need"/ want to increase braking power. It might just result in a potentially valuable contribution to the forum.
Thanks however for the ancillary information provided in your response. That's what automotive forums are for.
The master cylinder. booster. brake fluid, pads are all working as they should. The truck will lock the wheels and go into ABS. That however does not mean that the system cannot be improved. So if you know the answer to the actual question, feel free to answer.
Old Jun 4, 2018 | 07:42 PM
Dewilmoth's Avatar
2016 Viper ACR
I'm curious about the brake upgrade as well, solely for aesthetic reasons. But I may just end up having the calipers painted, I can't stand the raw metal of the standard calipers that gets surface rust after washes.
Old Jun 5, 2018 | 10:44 AM
KAHBOOM's Avatar
I
I see that Brembo makes a brake kit for the GL350/ 450/ 550. I would rather have something more subtle than their red calipers however. Perhaps silver or black. agree with you on the aesthetics as well.
Old Jun 5, 2018 | 05:45 PM
Mike450's Avatar
2015 gl450
Youll be talking 4 compleltly new spindels, pads and rotors, at minimum. Other harware? Dont know if anyone has been down this road, so possible.
And if we judge potential wheel fitment by the 20" sized options known to work on a GL63, youre also likely talking 4 new wheels as well if you go with the swap.
Bold idea and something that would be badass for sure, but doesnt sound cheap by any stretch.
What is going rate for used GL63 brake setup?
Old Jun 6, 2018 | 10:44 AM
NaviTimer1's Avatar
GL550
Sounds like an expensive proposition. I didn’t think about the possible hardware add-ons like sensors and modules. The brake characteristics and threshold for the ABS system could be very different, not just a rotor and caliper swap.
I'll get in touch with my Indy guy and get his thoughts.
Old Jun 8, 2018 | 11:38 AM
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
Probably cost abour $5k easy from dealer.
Old Jun 30, 2018 | 05:06 PM
Chedman13's Avatar
2014 Mercedes-Benz GL63 AMG
I'm willing to sell my front brake setup (AMG caliper, rotors and pads). Calipers have ~60k miles on them. I just replaced the rotors and pads, they have ~1k on them.
They are currently on my 2014 GL63.
Send me a private message if so.
Old Oct 23, 2018 | 10:25 PM
William Torres's Avatar
X166
PM sent.
Old Oct 24, 2018 | 11:53 AM
Jason B's Avatar
Will this fit a 2012 GL non amg?
Old Oct 24, 2018 | 01:29 PM
X166
Probably not since the 2012 is the previous body style; only way to find out for certain would be to research the OEM parts between the models: i use this site - https://www.mercedesbenzofdurham.com/parts-catalog.htm
Old Oct 31, 2018 | 01:59 AM
maximase86's Avatar
2013 GL450
The appearance pkg 20's seem to have a tight clearance with the wheels spokes and caliper. The fact that the GL550 and GL63 have slightly wider wheels with different offset (and wheel well flares), I think you might be running clearance issues on the face of the calipers and wheel spokes. That might be remedied by using a small wheel spacer potentially. I don't know if rotor diameter is going to be in place as well. It'd be nice if you knew someone with a GL63 to test fit your stockers on.
S
Old Nov 6, 2018 | 10:32 AM
X166
AMG Calipers Retrofit on GL550
I just finished my swap... however, i don't have the 20" wheels..they fit fine behind the OEM 21"s; I will take a picture with the wheels tonight to show the clearance on 21s.
AMG Calipers -retrofit on GL550
Old Nov 6, 2018 | 10:34 AM
Chedman13's Avatar
nice work! glad you found a set.
Old Nov 6, 2018 | 12:42 PM
Jason B's Avatar
So, now all we need to know is if this will work on the 2011 GL ?
Old Nov 6, 2018 | 01:59 PM
Chedman13's Avatar
Brembo has a different brake kit for that model so possible it might not work.
Old Nov 6, 2018 | 02:25 PM
NaviTimer1's Avatar
GL550
Looks incredible, I like the silver color, very classy from the standard Red. Do post pictures with the wheel in.
I'm also in the process of doing the same on my GL550, could you share the parts needed to do the conversion? Anything obscure besides calipers, rotors and pads?
Old Nov 7, 2018 | 09:45 AM
X166
Front Calipers in Silver, I got mine at Autohaus of Peoria, fair price... there might be alternative sellers, but Dan from Peoria was the most helpful:
- 1664212898 (right)
- 1664213798 (left)
Rotors: Zimmerman - FCP Euro, hands down best place to shop...i drove to the CT shop to pick mine up.
- 1664230512 x2
Pads - i did JURID for the fronts.
Am researching SS brake lines and will share once i figure it out.
The rear's will be swapped out in the coming weeks; pictures will have to wait till the weekend... this is the wife's dd.
Old Nov 7, 2018 | 11:07 AM
Chedman13's Avatar
What’s the website link you used? When you call they charge full msrp.
Old Nov 7, 2018 | 11:48 AM
kombifan's Avatar
2010 Mercedes GL450; 2000 Mercedes ML55 AMG; 2016 VW GLI SEL Stick!!!
https://benzparts.autohausofpeoria.c...664212898.html
Google is your friend 🙃
