Unstable on snow 2017 GLS AMG63
Old Dec 3, 2019 | 07:37 PM
llmorris75's Avatar
GL 450
We have had our GLS for 2 years. It seemed fine with the All Season Tires last winter but this year with only one inch of snow it was quite unstable (felt like the back would come around at any time). Tires are new and alignment just checked; was minimally out of alignment in back. No codes, etc. appeared.. Any others who have dealt with this? I know many recommend snow tires but this was fine last winter and the amount of snow was minimal. Thank you
Old Dec 4, 2019 | 04:49 AM
AkTech's Avatar
2011 GL350 (Sold), 2014 GL350
Just get a proper M+S tires. This is your own safety, why gamble?
Old Dec 4, 2019 | 06:51 AM
jbattan's Avatar
2023 Mercedes EQS 580 SUV, 2023 Bentley Bentayga, 2023 Genesis GV60
Get Pirelli Scorpion Winter Tires.
Old Dec 4, 2019 | 01:14 PM
llmorris75's Avatar
GL 450
I don't disagree with the snow tires, but my point is that this is different than it has been and something is not functioning correctly. Thank you for the input.
Old Dec 4, 2019 | 08:46 PM
chassis's Avatar
2017 GLE350 4MATIC
What does "come around at any time" mean? Can you explain the details, the last time this occurred?
Old Dec 5, 2019 | 09:21 AM
llmorris75's Avatar
GL 450
Chassis - it's almost like driving a two wheel car with no limited slip on ice where the slightest acceleration would make the rear come around. It seems to come around both directions though instead of just one direction as the old two wheel drive vehicles would do. It has only occurred one day when we had about 1/2" of snow on the road and the temperature was about 30 degrees. Just had alignment checked and corrected yesterday. It was minimally toed out in the read but probably not enough to cause this. Thank you all again.
Old Dec 7, 2019 | 08:29 PM
Forrest Gump 9's Avatar
shrimp boat
I know a lot of people would not agree, but try to turn off the traction control and see if that help.
Old Dec 8, 2019 | 08:46 AM
lauwersp's Avatar
2014 Mercedes-Benz GL550
So logically it would be either tires, suspension/alignment, or a sensor problem for the stability control. Sensor should be easily ruled out as it would throw a code and you’d know with every start that stability control was inoperable. An alignment issue CAN absolutely create the issue you describe at its traction limit. If you drive it hard on dry pavement I might expect that it feels a little squirrelly nearing its cornering limit, but I would understand if you didn’t drive it hard enough for that. Tires are the last thing and I will say GLs/GLSs are hard on tires. Take a good look at the tread. After 30K miles our (good) all seasons were destroyed and it snuck up on me. On the insides I had worn through steel belting yet you didn’t see that on the outsides. I finished the season on them and switched to the winters. Night and day difference. We had a hard time in the rain with the worn all-seasons. Obviously yours are probably not as bad as mine were, but don’t overlook carefully looking at their wear. That also being said, there is NO safety substitute for winter tires. No. Substitute. As you have a GLS63 I’m assuming cost isn’t an issue. Unless you live somewhere where snow is rare, winter are really the choice if you want to be safe.
Old Dec 8, 2019 | 09:04 AM
chassis's Avatar
2017 GLE350 4MATIC
From reading the GL posts, my opinion is M-B specs way too much camber, and a bit too much toe, and too little tire pressure on these vehicles. Additionally, tire tread design, compound and size play a role. I would say the reasons for this are ride quality and grip (safety). However the consumer pays a big penalty in tire wear.
Comments can be found on this site that "the GL is heavy". Yes, true. And that was an engineering choice by M-B. A Ford F-250 is heavy, and tire wear is excellent. The resulting GL weight requires certain characteristics of the suspension, wheels and tires. The combination of weight and other specifications chosen by M-B result in peculiarly fast tire wear, unfortunately.
Old Dec 8, 2019 | 10:04 AM
lauwersp's Avatar
As far as the “wear verses weight” issue, the fact that an F-250 is heavy too doesn’t mean that the weight and geometry of the GL suspension against the tires it’s spec’d for can’t wear the tires faster than the Ford. My comment is based on talking to service advisors and the third party high end European garage that we use for both our GL550 and Audi S8. I was surprised how our tires looked on our GL for the mileage they had on them. I’ve never in my life had tires wear as fast as they did on this car. Personally, I completely understand that tire wear is very secondary to handling and overall performance including comfort from MBs perspective. A better, more costly part is favored over poorer performance.
i know you ended up acknowledging this at the end of your post, I just thought that point was worth clearly making.
Old Dec 8, 2019 | 12:51 PM
chassis's Avatar
2017 GLE350 4MATIC
lauwersp, we agree fully. The GL eats tires because of suspension geometry decisions made by the manufacturer.
Old Dec 8, 2019 | 09:03 PM
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
Yes and because OEM front - there is only basic Toe "directional" adjustment. We saw the need therefore to re - instate from the early 90's once again full, precise, ongoing adjustment capability
FOR THE FRONT:
1. Replacement bushings for the 4 lower arms.
Advantage also is besides providing both Camber and Caster adjustment to resolve costly, premature edge tire wear and correctly fix steering pull. They also replace the 2 rear highest wearing bushings which are subject to premature failure (and OEM are expensive to replace).
KMAC kit also comes with bush extraction tools, so can be fitted without arm removal
#504016 M $595 Full set provides up to 1.5 degrees Pos or Neg Camber & Caster change.
#504016-1 P $695 provides up to 2 degrees Pos or Neg Camber & Caster change (lowered suspension)
2. Replacement upper arm inner bushings. This KMAC design provides up to 1 degree Pos or Neg Camber and Caster change. Also precise adjustment. With bush extraction tool so can be fitted without arm removal.
FOR THE REAR:
Replacement lower arm bushings
(highest wearing). Comes with bush extraction tool. Fit without arm removal. Provides double existing adjustment range. Single wrench precisely adjustable #504026 K $480
Delivery $40 one kit ($60 front and rear)
Can pay by PayPal, Visa or M/Card
