GL350 EGR valve replacement procedure
Old Mar 11, 2020 | 03:22 AM
AkTech's Avatar
2011 GL350 (Sold), 2014 GL350
Can anyone post replacement procedure step by step please?
Old Apr 10, 2020 | 12:22 AM
geniushanbiao's Avatar
2012 ML350 Bluetec, 2015 GL350 Bluetec
It's not a difficult job to do actually. Here's the procedures from WIS/ASRA.
1. Drain coolant (actually from my experience you only need to drain about 1/4 of the coolant in the system. The valve is mounted in a pretty high position).
2. Remove some of the body parts above the valve (including the cover, and left bulkhead), as well as the driver side air filter housing.
3. Disconnect the coolant hose on the valve.
4. Remove the 2 bolts holding the valve and lift it out. It might be a little difficult to lift as the body fits pretty tight in the bore, so you might need to get some help with a slide hammer or something.
Install is the reverse order. Make sure you cleaned the gasket mating surface and install a new gasket. Torque of the two bolts is 12Nm.
Old Apr 10, 2020 | 09:18 AM
AkTech's Avatar
Thanks! But already paid someone to do that price was actually around 100$, not bad. Dealer on the other hand would charge me around 500$.
Old Apr 10, 2020 | 09:26 AM
Stealership is being ridiculous on this. I feel dealers like those who send their cars in regularly or bought from them, but if you never been there before they would first rip you off. They like to have a steady customer instead of letting us decide what job we ask them to do or not.
Old Jun 25, 2020 | 04:49 PM
Ben Rogers's Avatar
GL 350
Yikes! I just got quoted $1300 to replace my EGR! I looked online to buy a new one and only found remanufactured parts. Does anyone know what the remanufacture process consists of for this part?
Old Jun 25, 2020 | 04:51 PM
Ben Rogers's Avatar
GL 350
I've seen a video on how to do this for a ML but not a GL. Is it safe to assume that the layout of the engine in the ML and GL are pretty similar? My vehicle is still at the shop so I can't compare it against the video right now.
Old Jun 25, 2020 | 05:07 PM
Exactly the same as long as the chasis version is the same. The W166 ML is from 2012 while the X166 GL is from 2013.
Old Jun 25, 2020 | 05:14 PM
I'm not sure what you are talking about by saying "EGR". The EGR system contains several parts. If you are talking about the EGR valve I would imagine the reman process to be a completely disassembly and check/replace of any wearing parts including bearing, motor brush, and gaskets/seals. Also the manufacturer might specify some specs on the parts and they should be checked and corrected as necessary during the reman process as well. But the reman standard might be different among providers though. That's why some providers do great job on reman but some give out products that fail fast. Basically if it's a reman parts from a reputable provider you can consider it to be a "like new" parts, with same performance and at least 80% life expectancy of the new parts. In some cases, although rare, reman parts last longer than new.
