Tires: Anyone getting more than 20k miles?
I've got a 2013 GL550 with the 21" AMG wheels. I know many have complained about tire wear. I'm glad there was some credit coming back to me...but it seems nuts that our tires wear out so quick. My new tires also come with 50k warranty and they tell me at DT that these will wear better...but I'm not holding my breath.
Any one having better luck?
My previous set was the DWS06 (I think I got about 22-24k miles out of them, with bald patch along inside shoulder) which was better overall compared to the Perelli Scorpion which sucks (think I got 16k miles, stiff ride and hydroplaned easily even when brand new). It still hydroplaned, not as scary as the Scorpion, but still often even when new.
Currently I'm running Yokohama Geolandar X-CV and it's the best so far. Great handling, low tire noise, great wet grip (starting to hydroplane a little going 65-70 through a heavy downpour) after 11k miles, none prior. I'm going to see how many miles these will offer, but so far it looks promising that it will surpass the DWS06.
- 36 psi all around seems to produce the best, even tread wear here in central TX
- Low-profile, performance rubber + nearly 3 tons = rapid tire wear
- Conti ExtremeContact DWS06 didn't make it through 13K miles, even with 2X rotations; got a treadwear refund on that one
- Conti CrossContact UHP fared a little better, but zero treadwear warranty
- Pirelli Scorpion Zero All-Season Plus did the best, with 4-5/32 even treadwear after 21K miles and regular rotations (then GL450 was sold)
- I decided to try the Yokohama Geolandar XC-V this time out to see if I could best the Scorpions for a little less $$. They, too, have 50K treadwear warranty.
- All tires purchased thru Tire Rack and shipped to and installed at a neighborhood Firestone store with lifetime rotation.
- Got lifetime alignment as well and check that regularly, since this vehicle eats through rubber more than any other consumable.
https://www.walmart.com/ip/Atturo-AZ...Tire/821933020
I replaced with 20" Bridgestone Revo 3s and the ride is nicer and I've put about 5,000 miles on them with hardly any wear.
Hadn't rotated them because it affects the handling so it's time to get a new set.
i await patiently the Mercedes EQC 400, sometime in my lifetime.
set. Found out they no longer make the Michelin premiers in my 19” size so switched to Bridgestone Alenza for wet handling on Florida roads. We’ll see what I get from these.
