Retrofitting tow components to non equipped GL
So you can install just the receiver in place of the impact bar (inner metal bumper on a non tow equipped) but suspect without the cast iron longitudinal pieces your tow rating greatly diminishes? But maybe I am wrong and the X166 does not use it at all? And the 8 studs on the receiver is sufficient? That’s my question. The frame box rails that support the impact bars with or without tow, I can’t imagine will take the punishment without the cast iron pieces reinforcing the structure.
I guess if you just want bikes or cargo boxes the 8 studs is sufficient. I can’t see under my to confirm if things changed and holes for the supports are even present.
For more information check out these threads. x166 Factory Trailer Hitch Install - Need additional information, & Able to add trailer hitch to GL?,
Jeff
Im gonna assume the x166 does have these braces. That was my original curiosity. Bumper and exhaust need to come down to get to the bolts if that’s the case.
I still need to find a deal on the foam impact that is tow reinforcements specific.
166 315 00 65
Then the tough decision to do factory wiring or universal.
Universal no splice option.
I think the below three items is the sauce for to get it wired up with the factory stuff. Plus a dealer programming.
Here is a video of the Tekonsha install on a ML
The items purchased so far
If you don’t want to use the factory receiver and braces, Curt sells an aftermarket solution that will do 7k lbs but just like the factory installation it’s a little more involved. Curt also sells a more modest version, similar to installing just the factory reinforcement without the longitudinal bars.
I prefer factory hardware as it’s more stealthy and usually more rust resistant.
Below is the heavy duty hitch 13190 to maintain the 7000lbs capacity. Notice the brace that wraps around the exhaust to a support on the rear axle area.
https://www.curtmfg.com/part/13190
The project has become a little involved. The little treasure box holding a suspension component needed to be moved to get to the last impact bar stud nut. Still I also hope I can do this without doing too much with the exhaust. The longitudinal bars seems to be secured from the spare tire compartment.
Taking my time with it. I don’t want broken plastics or hardware. I’m am a stickler for broken parts.
The red mark up is how I ran the two power wires one will go to the light controller and other one will go to the 7 pin connector to power a wireless brake controller in the future If ever needed.
Stop wire, LH
Right turn signal
Parking and LH turn signal
Right turn wire tucking
It works!
A tester is a great tool for this. The LEDs represents the parking, turn signal and Stop, stop with turn signals and then parking off.
I only dropped the exhaust and undid the two rearmost exhaust shield fasteners, and force it it down to give access to the two lower nuts for the impact bar.
Longitudinal braces bolt location
Foam impact
Reverse installation
This bracket has to be moved to get to the treasure box.
Meanwhile, how did you manage to tighten the 4 lower bolts of the 2 hitch mounting plates (lower 2 of each plate)?
Isn't the heat shield on the way? I understand that the nuts of the bolts that hold the shield brackets and the hitch plates on the car, are actually behind the mounting points. Did you have enough space behind to fit a wrench?
Also did you use a torque wrench? If yes at what ft./lb or N/m specs?
Thank you.
LL
I am ready to go for it, but as you mention above, I have the diesel version meaning that the bluetank also needs to get lowered. I am a not sure if it will be a hassle and also I don't want to make any damages.
Also, I am not sure how easy it is to take off the rear bumper. Was it hard to take the bumper off?
Local MB dealership quoted me for 3 hours ($600) to install just the hitch....maybe not a bad price after all.
Thank you.
You need to set aside a weekend to not rush, the bumper scared me but once you figure how it’s comes off it’s easy to manage. Look at my pics for guidance on the hardware. One hex screw per side by pulling the liner to the side and 6 on the bottom/ 3 per side, and four at the rear. The little screw if you have the AMG pack. The pull outwards and backwards, carefully working the taillight area clips, a small screw driver to help release the tabs.
gonna try it again in the daylights.
