Sagging Rear Suspension
Old Jan 13, 2022 | 06:11 PM
MartinC2S's Avatar
GL350, C43 Wagon, 911 C2S
Hello All,
I've got some familiarity with air suspension systems on my old Touareg and current Cayenne but I am now in the market for GLS and could use some input from the folks here. A '18 model at an MB dealership came up for sale kinda close to me and the sales guy sent over a couple pictures. One of them shows the car on the lot with the rear end sagging significantly. I raised the issue with him and even asked him how it was CPO'ed if the suspension sags. His response was that "they all do that when parked for an extended period of time". Now, in my experience this has never happened on any of the air suspension equipped cars that I've owned. It's a sealed system and if the car is sagging that means there's a leak. The sales guy is adamant that everything is ok and that it was properly checked over by the service department.
Usually, I would just chalk this up to the usual "sales guy not knowing the mechanics of the car he's selling" syndrome but he later sent over a picture of a brand new '22 GLS sitting on their show room floor that is also sagging in the rear.
What do you all think? Is there any validity to this? Is there any documentation to support his claims? I'm still hesitant to believe him.
Old Jan 13, 2022 | 06:45 PM
w220430's Avatar
2024 GLS 580. Formerly 2015 GL 550, 2003 S430.
The salesperson is full of *****. Most likely there is a leak in the rear suspension. This exact thing happened to my 2015 GL550 just a few months ago, cost me around $1800 or so to to fix both rear sides.
Old Jan 13, 2022 | 08:46 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
They raked you over the coals. The airbags can be had for a few hundred dollars and they take around 15 min to install.
Old Jan 14, 2022 | 12:57 AM
MartinC2S's Avatar
Haven't been raked over yet as I haven't actually puller the trigger on the car. I'm with you guys but the thing that's odd to me is the picture of the new one sitting in the show room with a sagging rear end. How do you explain that?
Old Jan 14, 2022 | 11:07 AM
Tiffany's GL450's Avatar
GL450
Gorgeous looking car!
My '13 GL450 also settles or deflates if it has been sitting over night. I agree that it is a sealed system but I wouldn't rule out that leaks could be coming from may places within the system. Fittings (tee's, elbow's, 4 way's and couplings) or a hairline crack in one of the lines going to and from the bag or the compressor. From what I understand, and read on here and a couple of other forums, the compressor is adding air to the system multiple times while the vehicle is in use as needed.
When I jack the car up to change the fluids or when I got new tires and wheels put on, I set it back on the ground the bags have completely deflated, looks like I put a drop kit on it! Start the car and within a few seconds the car is back to its original height. Right or wrong, I am not too concerned with it, if one of the struts fail then I will simply change it and move on, no big deal.
Chad
Old Jan 14, 2022 | 12:47 PM
cadetdrivr's Avatar
2014 GL350
The problem with excessive sagging over the long term is the compressor failing from overuse when it's forced to run all the time. Wait too long to replace a failing bag and you might get to replace the compressor as well.
Old Jan 14, 2022 | 01:12 PM
GL450
I'm not trying to be a smart *** here, just trying to learn more about the car, but, is there a 'Range or Time' for excessive compressor use or excessive sagging?
What am I gauging here? Should I measure the drop overnight to see how much it dropped in a given time? Should I time the on/off cycles of the compressor to see what's it running and for how long?
What parameters should I be using and or monitoring to see if what my car is doing is an indication of a failing component?
Thanks man!
Chad
Old Jan 14, 2022 | 01:49 PM
cadetdrivr's Avatar
2014 GL350
Thanks man!
Chad
Great questions. I don’t know the parameters where one would want to preemptively replace a bag, but I can state that our eight year old GL does not sag at all so I would not consider sagging normal.
Old Jan 14, 2022 | 02:54 PM
BlownV8's Avatar
My 15 year old GL does not sag nor does my 8 year old GL regardless of how long it sits. If it sags, there is something wrong in the system/components.
Old Jan 14, 2022 | 03:30 PM
GL450
Thanks gentleman, this is something I will be looking into. Have a great weekend!!
Chad
Old Jan 17, 2022 | 10:47 AM
MartinC2S's Avatar
Thanks everyone. I've crossed that car off the list and am about to pull the trigger on a pristine '14 GL350 with only 40k on the odo if all the final checks are green.
Old Jan 18, 2022 | 10:00 AM
OnlyGerman's Avatar
Too many german broads
I would of had them replace part of the deal!!!
Old Jan 18, 2022 | 10:11 AM
MartinC2S's Avatar
The car wasn't at the top of my list anyway. Was missing a few key options and the mileage was higher than I wanted. I was happy to have a valid reason to pass on it.
Old Jun 17, 2022 | 02:48 PM
bakestein1's Avatar
2018 GLS 550
Chad
Have you noticed anything or found an issue? My 2018 GLS 550 looks like a low rider when I jack it up to change the oil…
Old Jun 17, 2022 | 08:05 PM
arsupisemnet's Avatar
2014 GL450, 1992 W140 300SD, 1993 W140 300SE, 1987 E30 Convertible
Your height control keep working all the time. To prevent suspension drop during jack up is to remove fuse
Old Jun 17, 2022 | 08:11 PM
GL450
I was incorrect in my "Sagging" statement, what I noticed was that since our driveway is on an angle, the car tries to level out. When we back up into the street it airs up to a flat surface as it is suppose to. So I'm 99% positive the car is fine, but I am monitoring it weekly!
bakestein1;
What you have experienced is normal, mine does the same thing every time the wheels come off the ground. Oil change, differential fluid change, trans fluid change, brake fluid change, rear end fluid change or any other reason the car is off the ground it thinks its flying!
When you come in for landing the car goes Chicano and on the floor it sits!! Which for about 3 minutes is kinda cool looking, then the car rises and goes back to normal configuration.
My first oil change I thought I broke something because it was on the DOWN low. Wife was crying, dog was howling, kids were running. Went inside to get on this forum to see what in the hell I did to the car, came back outside and it was sitting normal. I thought I was losing my mind, I could have swore that car was broke and now it looked normal. Even contemplated not drinking cold beer while working on it!!
You should be good to go!
Chad
Old Dec 20, 2023 | 09:38 PM
FWP!'s Avatar
2017 GLS 550
Because the self-leveling suspension tries to do its thing while you're jacking up the car, even when the car is turned off.
The trick is to just open one of the doors, even if you just pop it open and then mostly close the door. The suspension is basically not allowed to move while any of the doors are open, thinking that there is someone entering or exiting the vehicle and so it wants to stay as still as possible.
Old Dec 20, 2023 | 09:39 PM
FWP!'s Avatar
2017 GLS 550
100%. The dealership would make it sound like a big deal to change them, using that as a bargaining chip, all the while they absolutely know it's a really easy and cheap fix on their end.
