Air Conditioning becoming mediocre
Old Apr 29, 2022 | 03:23 PM
mcoady1's Avatar
2017 GLS450, 2013 GL450, RIP 2011 GL450 (totalled)
Anyone else have their air conditioning temperature become mediocre? Its cool now, but not cold and quick like it used to be, and when it gets cold it takes a bit of driving. Scanner said refrigerant is 13.5 bar on 83 deg F day, did have a power supply low historic code saved. Wondering about anybody else's experience with this. Compressor engaging?
Old Apr 29, 2022 | 05:14 PM
oldmangrimes's Avatar
GL450
On my 2013 GL450 it's never been very good, but I bought it two years ago with 80k miles, so I don't know how good it was new. The compressor is running, it puts out cold air, just not ice cold. It's not as cold as my other cars that have good AC. I've got the panoramic roof so it gets pretty hot if the windows are rolled up and it's parked outside. I have a iCarsoft MBii scanner, and I just read that it can check the pressure so I will do that soon. I'm curious to hear if others have had good luck with simple recharges on these.
Old Apr 30, 2022 | 01:05 PM
arsupisemnet's Avatar
2014 GL450, 1992 W140 300SD, 1993 W140 300SE, 1987 E30 Convertible
Change between modes... Most likely you are on diffuse...
Old Apr 30, 2022 | 01:45 PM
chassis's Avatar
2017 GLE350 4MATIC
Scan using XENTRY. Detailed diagnostics and operating parameters will be displayed showing target and actual values.
Evap outlet temp should be in the 40s.
Old Apr 30, 2022 | 02:49 PM
mcoady1's Avatar
Dropped it off at mechanic today, he said pressure was low and recharged it. Couldn’t find leak but he put dye in it to trace it down should it get low again. We’ll see!
Old Apr 30, 2022 | 03:11 PM
chassis's Avatar
2017 GLE350 4MATIC
Look at the vapor line from compressor to condenser. Mine is slightly leaking from the crimp at the compressor. It is a slow leak and XENTRY says all the temps and pressures are in spec. AC blows cold so I’m keeping an eye on it. I have the hose in case it needs to be replaced, the parts guy said I bought the last one in the country last year.
Old Apr 30, 2022 | 06:15 PM
E55Greasemonkey's Avatar
This place is a joke.
It's normal to have to evac and recharge these cars every 5 years or so. The freon doesn't last forever, some of it leaks, some may break down chemically, but this is essentially a maintenance item. Newer cars hold such a small amount of freon that a small loss of say 10% noticably affects the cooling capacity.
Old May 12, 2022 | 04:16 PM
sdwtchlvr's Avatar
2013 GL550
I had mine charged up last year and it’s been great since.
Before it was blowing not so cold and I noticed a faint swirling/swishing sound coming from the vents. Did some reading online and read that sound can indicate low refrigerant.
I have a 2013 550, purchased in 2018. Just for reference.
Old Aug 8, 2022 | 09:51 AM
Tiffany's GL450's Avatar
GL450
My wife's 2013 GL450 blows cold on the Passenger side but the Drivers side is cool, at times its even just air and not conditioned air. But the passenger side stays cold, after some driving the Drivers side seems to be getting colder but not like the Passenger side.
Is the fault of a blend door actuator or temp sensor of some sort? Or do I need to have the system cleared of the old freon and new freon put back in?
Chad
Old Aug 8, 2022 | 01:36 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Chad
Forget the parts canon, parts are hard to come by these days!
You need to have it scanned to check what the AAC computers has to say.
Actuator and sensor are excellent guesses. Scanner will tell!
Usually the bad temp sensor is on passenger side, broken during filter service.
Speaking of which... do replace or remove cabin air filter to get good flow over the blower ballast module.
Old Aug 10, 2022 | 01:20 PM
GL450
Filters were replaced at the B Service with K&N and Factory Filters earlier this year.
Is that temp sensor in the immediate area where those 3 filters are at? Would you know the official name of the temp sensor, like AC Temp Sensor or something similar?
Thanks for the help!
Chad
Old Aug 10, 2022 | 01:38 PM
"THE sensor "
... there is a dozen sensors involved in Mercedes A/C - This system definitely far from basic.
The most frequently disturbed sensor is on the passenger footwell cover but I wouldn't try to get away with only guessing ... scan
Old Aug 10, 2022 | 02:00 PM
GL450
Scan, looks like a dealer or shop will have to do it. I only have a basic-generic-cheap scanner used for reading codes only.
Rats!
Chad
Old Aug 10, 2022 | 02:17 PM
GL450
Do the MB's use a particular scanner or would a Auto Shop that uses Scan II or OBD Scan Tool be able to determine what the AAC Computers have to say?
Chad
Old Aug 10, 2022 | 09:24 PM
chassis's Avatar
2017 GLE350 4MATIC
XENTRY is the MB dealer diagnostic tool.
Old Aug 10, 2022 | 09:32 PM
Chad
an iCarsoft handheld scanner will read everything AAC module has to say.
You need a $150 Benz specific scanner not a basic $39.99 special...
Xentry is the reference 👏
Old Aug 11, 2022 | 06:19 AM
BenzNinja's Avatar
Former Vendor
I'm here
Old Aug 11, 2022 | 09:06 AM
GL450
Thanks gents!
Chad
Old Aug 13, 2022 | 08:14 AM
GL450
So the Air Conditioner has no codes, a friend of mine has a Matco Scanner and hooked it up. The scanner revealed 93 codes that varied from Communication or Open Signal / Internet Signal Loss or Missing Message / Low Power Supply and other codes that I would consider nuisance alarms or codes. Nothing related to the performance of the car or the Air Conditioner.
I find it odd that none of those codes or faults showed on the Display, it is clear, only the scanner revealed these codes.
The one parameter or fault I was looking for: AC - Air Conditioning(N22/7) showed no faults. But yet the AC is as first described, cool on the drivers side, cold on the passenger side.
I'm going to take it to a shop and have the ac system evacuated and the Freon replaced, see if that fixes the problem. Is this one of Mercedes Letter checks perhaps? Like fluid changes and filter replacements at a pre-determined intervals?
Chad
Old Aug 13, 2022 | 08:39 AM
GL450
I think I might invest on a more robust scan tool, one that I could scan the Wife's Mercedes and my GMC Truck and my Camaro.
I seen a guy on here using an iCarsoft scan tool so I found their website and seen different models.
One in particular shows to read multiple vehicles, the iCarsoft CR Elite scan tool, (https://www.icarsoft.com/Product/s-3..._cr_elite.html) any thoughts on that scanner or perhaps a better scanner for less the $300?
I think it's time to upgrade!
Chad
Old Aug 13, 2022 | 12:38 PM
BenzNinja's Avatar
Former Vendor
Chad
see you in 3 month's
good luck
Old Aug 14, 2022 | 05:38 PM
GL450
good luck
Tell ya what dude, if you hadn't been a ***** saying "see ya in 3 months" I might have considered your service. But instead you can go pound sand!!
Please stay off my Post, I'm looking for help not wise *** comments!
Chad
Old Aug 14, 2022 | 06:14 PM
overfilled from factory?
a while back @chassis shared his solution to increase A/C cooling was to decrease R134 load... I buy that.
Mine was to wrap the A/C lines to minimize engine heat transfers.
Thinking it over both of the above solutions decrease pressure to increase cooling!
With higher heat, the pressure of the high side liquid increases and the compressor gets a higher head to pump gas around.
The resulting pressure increase on the low side limits the evaporation of a warmer liquid into gas.
Old Aug 14, 2022 | 08:38 PM
GL450
Thanks man, I plan on taking the car to a shop this week to have the AC looked at
Chad
Old Aug 14, 2022 | 09:53 PM
Chad
With the level of heat this summer, frigid A/C is not an option - Let us know what made a difference to get your A/C cool again... 😎
