TPMS fault
Old Aug 20, 2022 | 11:23 AM
LIRS6's Avatar
'14 GL550 , '79 911SC
TPMS fault
2014 GL550, 105k miles.
dash warning that tire pressure needs to be adjusted on FR. However the pressure is what it should be, and is the same as the FL tire.
So the warning showing issue with FR pressure is not correct.
I don’t believe it to be the individual sensors, as the pressure for each wheel changes over the course of driving the car (tires heating up).
I presume that it is the TPMS module, but does anyone have any input?
thanks
jason
Old Aug 20, 2022 | 12:20 PM
LIRS6's Avatar
Here’s a photo of what I am referring to:
Old Aug 20, 2022 | 05:22 PM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
You need to reset the TPMS to clear the error. Mercedes-Benz E-Class: How to Reset Tire Pressure Monitoring System (TPMS) | Mbworld
Old Aug 20, 2022 | 06:27 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
case of "user error"...
yes, +1
Once you want adopt the pressure you like for your car, you set it once so the car will warn you about differences.
Now the message is warning you of such difference compared to what was saved last time...
Old Aug 23, 2022 | 11:11 AM
LIRS6's Avatar
Thanks vm - I was hitting "OK" while system was showing the pic I posted, thinking that's how it was cleareed.
All good now.
Old Aug 24, 2022 | 03:41 AM
AkTech's Avatar
2011 GL350 (Sold), 2014 GL350
removed
