GL63 AMG and GLS63 (X166, X167) 2014 - present (Two generations)
Lowering for better stance
Old Aug 25, 2016 | 12:13 AM
kfehling's Avatar
2015 C63 AMG S Edition 1, 2021 GLS63, 2020 McLaren 600LT Spider
Has anyone lowered their GL63 for a better stance? I have done some searching here but have not found anything. I have a 2015. Thanks in advance.
Kurt
Old Aug 25, 2016 | 10:08 PM
Chedman13's Avatar
2014 Mercedes-Benz GL63 AMG
Yes, I have the Brabus lowering module. There are other options as well:
https://www.gmpperformance.com/index...=6084&VID=4379
Renntech and H&R both make options.
Old Jan 25, 2018 | 05:42 PM
traumadoc's Avatar
2022 AMG SL 63. 2021 APR stage 1 Audi SQ7.
Renntech comint tomorrow for my GLS 63. Let me know if interested in pics.
Old Feb 11, 2018 | 10:07 AM
Chedman13's Avatar
Post pictures!!
Old Mar 17, 2018 | 12:43 AM
traumadoc's Avatar
Sorry late.
Old Jun 28, 2018 | 03:15 PM
ramie's Avatar
07 C230 Sport
Traumadoc was that a easy plug and play to lower you GL63?
Old Jun 28, 2018 | 05:02 PM
traumadoc's Avatar
Easy
takes less than 2 minutes. In fact, I keep the module in the SUV in case I want to raise it to stock.
Old Jun 28, 2018 | 11:00 PM
ramie's Avatar
07 C230 Sport
Any alignment problems? Was the ride a little more harsh.
Old Jun 28, 2018 | 11:01 PM
ramie's Avatar
07 C230 Sport
Any alignment problems? Was the ride a little more harsh. Thanks Doc
Old Jul 24, 2018 | 12:55 AM
black06c230's Avatar
mgLipGD
Lowering Links
Old Feb 3, 2019 | 02:09 PM
carlosamg50's Avatar
AMG GLS63
Im thinking lowering links too, only 10mm or so nothing too much, maybe just to flatten the very minor body roll in S mode, S+ is too much on UK roads
Old Aug 30, 2022 | 12:33 AM
CamJ72's Avatar
GL 63 AMG
What did you use? What model .. sorry if I missed it. Love to also hear about impacts? ride or anything else to consider. Thanks !
Old Aug 16, 2023 | 08:05 AM
BenzNinja's Avatar
Former Vendor
We lower to Euro specs, original MB designed specs. great looking and for a unbeatable $250
Old Aug 16, 2023 | 08:09 AM
egorijjj_mwmods's Avatar
IG: @loweredbenz
​​​​​​​It is possible to change the suspension clearance with the OBD2 module from MWMods.
Portable device, easy to use.
You can adjust both front and rear separately, in 1mm increments.
Maximum down to -40mm and up to +40mm.
Details: lowering module
Old Aug 17, 2023 | 07:31 AM
svtbolt2001's Avatar
2008 F250
Looks good. Curious if the inside area of tires will wear faster due to camber and IRS.
Old Aug 17, 2023 | 08:32 AM
IG: @loweredbenz
Yes, it will. The lower the suspension is down, the more the tires will wear on the inside.
Usually for GLS's the suspension is lowered no more than -15-25mm.
At those values the wear won't be significant, but I would still advise leveling the negative camber.
Old Aug 18, 2023 | 10:04 AM
C43 Fun Haver's Avatar
2015 ML63
I purchased the lower module from MWmods for my 2015 ML63 about 4 months ago now. Zero issues with it, takes only a minute to adjust your height through the radio commands & level out to where you want her to be sitting. I know its not the GL like this thread is for but whatever.
My ML sits low now, improves the look a lot with such a simple mod.
Old Sep 27, 2023 | 12:43 PM
IG: @loweredbenz
Thanks for the feedback!
Our module works with both ML and GL classes. The module can be used to raise or lower the suspension. The front and rear can be adjusted separately.
Each step is one millimetre.
You can raise the suspension above the factory height, or lower it.
Max/min: +/- 2.5 inches from factory
mwmods.com
*Package deals for forum members
Old Sep 28, 2023 | 08:02 AM
BenzNinja's Avatar
Former Vendor
Old Sep 28, 2023 | 08:14 AM
IG: @loweredbenz
We are also ready to offer good terms and conditions for forum members.
Write to me at info@mwmods.com or in private messages.
