DME Stage 2 Tune With Stock Cats
Johncy
I spoke with my Master MB tech about this in detail. The spark plug is indexed (must face a certain way) and if the tech senses any damage to the plug or is dropped, he will throw it away and use a fresh one.
Even if you call Renntech who used to recommend different spark plugs, now has gone back and recommends OEM spark plugs.
Weistec still recommends different spark plugs.
I also run a 91 octane tune - the difference in HP for a 93 octane tune is non-material and in case you ever run into a situation of not having 93 or getting bad fuel - just protects your engine from knock.
Use OEM spark plugs and change them every 30k miles for tuned cars if you want to play it safe.
He has also seen a case of the filter deteriorating and getting into the engine and ruining it.
I'm not going to risk and and sticking with stock. If I were to change filters, I'd use the Blackboost which I believe uses BMC, but I'd get that just for the sound=)
I doubt you'll run into issues, but just sharing.
