I have a 2019 GLC 63 and I was unable to drive my truck for two weeks. So I had to actually jump start it when I got back home. However my lift gate now will not open automatically. It was working fine up until this point. I found a video that said that it may need to get recoded and wanted to know if anyone else has had this problem and if so what is the fix. I fear if I take it to the dealership they are going to try to say I need a new motor and over charge me. If anyone have any information or any solutions I appreciated it.
W205C43PFL
close
- Join DateDec 2019
iTrader Positive Feedback0
iTrader Feedback Score(0)
Liked:6,283 Times in 5,452 Posts
Quote:
Are you sure it wasn't a blown fuse from the jump start?Originally Posted by Kingsean74
roviw1
close
- Join DateNov 2018
- LocationHampshire , UK
- Vehicle(s) I drive2015 S500, 2016 GL63 AMG
Liked:65 Times in 56 Posts
Quote:
This may help you, I had my 2008 GL420 stood for a while prior to selling it, a couple of days before the guy was coming to look at it I took it for a run and also found the tailgate did not operate correctly.Originally Posted by Kingsean74
I thought it may be a low battery issue so charged the battery and all seemed well.
That was before christmas and the guy ( he is a friend ) has not had any issues since.
This leads me to think the lowish battery may have caused it, not sure how, but all ok now anyway.
W205C43PFL
close
- Join DateDec 2019
Could it be caused by a bad aux as well?Originally Posted by roviw1
This may help you, I had my 2008 GL420 stood for a while prior to selling it, a couple of days before the guy was coming to look at it I took it for a run and also found the tailgate did not operate correctly.I thought it may be a low battery issue so charged the battery and all seemed well.
roviw1
close
- Join DateNov 2018
Quote:
not sure, in the GL the aux battery is very tiny and not easy to get at. In the 6 years I had the GL I did not change the batteries at all. Originally Posted by W205C43PFL
W205C43PFL
close
- Join DateDec 2019
Quote:
I see.Originally Posted by roviw1
W205C43PFL
close
- Join DateDec 2019
OP, do you hear the mechanism unlocking at all, did you try manually lifting it if it was unlocked?
W205C43PFL
close
- Join DateDec 2019
OP, did you try checking if you accidentally hit the valet switch in the glove box?
ExploreBlownV8
close
- Join DateAug 2003
- LocationIn my garage
- Vehicle(s) I driveE55, GLS450, GL63, GLE350
Liked:1,212 Times in 969 Posts
You may get better advice in the GLC AMG section.
W205C43PFL
close
- Join DateDec 2019
Quote:
Perhaps OP should ask a moderator to move the thread over.Originally Posted by BlownV8
