Active Curve System Malfunction
new to the forum. Got my GL63 a year ago from my uncle who is AMG obsessed. The problem developed a month later after some regular maintenance servicing at a local independent shop.
i just replaced both front air struts, had a failure on the driver side a few months ago and just did the passenger a few days ago. Will be replacing the rears and both rear shocks too. Anyhow, the issue pops up on curves that make the vehicle lean to the right. It feels like something lets go up front on the driver side for a moment, and you’ll hear a very slight pop.
my hydraulic fluid is clean and no issues with the top popping off. I’m leaning towards replacing the sway bar links and bushings. Any insight would be amazing. Thank y’all.
dbj
Do the links and bushings first. It's the most likely fix and a lot cheaper than chasing other ghosts.
dbj
