GLA Class (X156) Produced 2013-2020
Halogen Headlight Bulb Replacement
Old Oct 24, 2014 | 10:35 PM
yuzone's Avatar
W213
Hopefully this thread will be helpful for anyone who's unlucky, like me, that purchased/leased the GLA250 without the Bi-Xenon package.
So I got this well loaded GLA250 with Premium, Multimedia and Sport Package , plus some interior extras, with a window sticker of MSRP $42,160
And, despite I'm mostly satisfied with it, it's missing the bloody $850 bi-xenon package...........
As a result, the tiny yellowish halogen light from the old-school reflector halogen housing is just ridiculously cheap looking and ruins the entire car completely, especially when the low beams and the DLR are both lighted on in the night... A Facebook friend who live in UK even asked me if I bought a used 2012 A class....
Since MOD is not allowed with a lease, retro HID is out of the question.
So my only option is changing the OEM cheap yellowish halogen bulbs with good halogen bulbs produces 'xenon like cool white lights', which I already did once for my ML350. (which is missing the lightning package too....)
The 2015 GLA250 manual listed bulb used for the low beams are H7 55W, which is pretty common used bulb. I've ordered a pair of Phillips Diamond Vision Halogen Bulb to replace the low beams bulbs, will post pictures after the bulbs arrives
Yet the Highbeam / DRL bulb of GLA250 appears to be the H15 15W/55W. So far I haven't found any available replacement bulb to fit.
I've looked at Phillips, PIAA and Sylvania; none of them have any H15 bulbs available yet...
Does anyone has any suggestion regarding the replacement of H15 bulbs? Even unknown makers from ebay will be okay, as long as they have the blue tints and produces white lights. (no 'HID conversion' kits, please)
Without the replacement of OEM H15 bulbs, the White low beams + Yellow DRL gonna be a weird combination. I'll basically turnoff the DRL before I can find a replacement for the tiny yellowish OEM H15 blubs...
I'll keep this thread updated on my findings for the H15 highbeam / DRL bulbs too...
Thanks,
- a depressed GLA250 owner
Attached Thumbnails Halogen Headlight Bulb Replacement-img_4310.jpg   Halogen Headlight Bulb Replacement-img_4335.jpg   Halogen Headlight Bulb Replacement-img_4333.jpg   Halogen Headlight Bulb Replacement-img_4350.jpg   Halogen Headlight Bulb Replacement-img_4345.jpg
Old Oct 27, 2014 | 04:14 PM
cleankutazn's Avatar
GLC 2026
That's the one option with mercedes you do not skip on. I did it once and would never do it again. It makes the car look totally different.
Old Oct 27, 2014 | 05:23 PM
yuzone's Avatar
W213
Hmmm when I got my 2014 ML350 without Lightning Package I was totally fine with it, since it got the LED DRL anyway. The ML350's $1,290 lightning package is merely for the Adaptive Xenon Headlights. Later I switched the factory bulbs with PIAA and they look as good as those equipped with the lightning package.
But with the GLA250, it's a different story, since the LED DRL is embedded into the Bi-Xenon headlight. The $850-Xenon Package is really a must-have..DRL without the Bi-Xenon package is UN-acceptable and I'm almost thinking about putting the GLA onto swapalease...
Old Oct 28, 2014 | 04:50 PM
jimbonyc's Avatar
2012 ML350
I've seen h15 5300k bulbs available on eBay. With that said I have a GLA on order and just added the bi-option rather than spend 125-150 for two sets of hid look bulbs to cover the low beams and hi beams/drl. Those aftermarket bulbs tend to not last very long either in my past experience so will need to be replaced often.
Old Oct 28, 2014 | 08:52 PM
yuzone's Avatar
W213
Yep.. Their life is around 6~10 months usually.. ;(
Old Oct 28, 2014 | 09:02 PM
yuzone's Avatar
W213
The bulbs arrived and I've installed them to replace the OEM bulbs.
In the pictures below, OEM bulb is on the passenger's side , Phillips Diamond Vision is on the Driver's side.
Old Oct 28, 2014 | 09:52 PM
jimbonyc's Avatar
2012 ML350
Looks much better!
Old Oct 29, 2014 | 11:47 AM
greasykid's Avatar
2015, ML250 BlueTEC
Better lights
Thanks,
Try candlepower.com Bought OSRAM 65watt bulbs from them for my C350 COUPE. Large improvement. Cost under $40. They have a very large variety of bulbs and were very helpful. Give them a call.
Old Oct 30, 2014 | 10:00 AM
GLC 2026
You should see what they did with the E class on the lighting package
Old Nov 3, 2014 | 06:20 PM
Boris_Balkan's Avatar
SLK55 //AMG R171
I followed your lead Yuzone, and I ordered 4sets of Philips diamond vision. They look fantastic! They have a very very slight bluish tint that does not look ostentatious or cheap.
Since these types of bulbs tend to have a shorter life, I'm keeping 2 sets in my car, and working on making a quick access panel to change the bulbs easier until some aftermarket headlights are available for the GLA's.
Thanks for posting Yuzone
Old Nov 3, 2014 | 08:49 PM
yuzone's Avatar
W213
Great !!! I'm glad that you like them
Since we already got a solution for the low-beam H7 bulbs, I've been searching for a good H15 bulb to replace the OEM bulb for HighBeam / DRL .
I just got a pair of "GP Thunder 7500K H15" from amazon last weekend. After installing them I found the high-beam light omitted by these bulbs are the nice-looking 'cool white'...yet for the DRL they're still producing is a weak yellowish light. Seems like we'll need to find a bulb produces white light even being lit on a low power...
Old Nov 4, 2014 | 11:37 AM
SLK55 //AMG R171
Any bulb we put into the high beam slot is going to be yellow because in DRL-mode, it is only giving out a reduced percentage of light. One possible option would be an H15 LED bulb that cannot be dimmed, so it is constantly putting out the optimal color temperature. They make LED bulbs in standard fitments now, however, finding an H15 might be tough in LED form...
Old Nov 4, 2014 | 11:38 AM
SLK55 //AMG R171
Found some! http://www.ebay.com/itm/Xenon-White-50W-H15-CREE-LED-Bulbs-For-Audi-BMW-Mercedes-VW-For-Daytime-Lights-/380990480306?pt=Motors_Car_Truck_Parts_Accessories&hash=item58b4cd5fb2&vxp=mtr
Need to find resistors though....
Old Nov 4, 2014 | 08:37 PM
yuzone's Avatar
W213
How about these: They're labeled as 15W /55 W, meets the specifications in the manual.
I don't have experience with this website tho. It also seems there gonna be a sale on 11.11.
http://www.aliexpress.com/item/Free-...055070259.html
They also have the ''LED Warning Canceller and Resistor" :
http://www.aliexpress.com/store/grou...212288798.html
Old Nov 4, 2014 | 09:14 PM
yuzone's Avatar
W213
Ordered a pair of this:
http://www.aliexpress.com/item/80W-C...802130488.html
I'll post update with pictures after its arrival and installed
Old Nov 5, 2014 | 12:05 PM
SLK55 //AMG R171
Looking forward to the update!
Old Nov 6, 2014 | 06:58 PM
SLK55 //AMG R171
I still can't get over how much the Philips Diamond Visions look just like factory HID's! I think people will be very pleasantly surprised.
Old Nov 6, 2014 | 10:59 PM
yuzone's Avatar
W213
Yeah
Old Nov 7, 2014 | 06:15 PM
Mort's Avatar
Yeah
Yup...been using them for 4 years in my fog lights and hi -beams.
Old Nov 8, 2014 | 05:32 PM
SLK55 //AMG R171
Nice! Thanks for chiming in, makes me feel better about the 3 sets i have now LOL
Old Dec 15, 2014 | 11:09 AM
juol's Avatar
2015 gla
adjusting and replacing lowbeam lights h7
hello everyone. is there any way you could adjust the position of the bulb or headlight a little higher. and how do you remove and LOCK the lowbeam h7 bulbs in on the 2015 GLA? thanks in advance
Old Feb 10, 2015 | 04:54 AM
Ansron's Avatar
Mercedes CLA250 4Matic
Hey yuzone, any update on the LED H15 bulb? Did it work? Do you need the resistor mod?
Thanks.
Old Feb 10, 2015 | 11:54 AM
yuzone's Avatar
W213
Thanks.
Hi Ansron,
They did work good without any resistor. Basically it's a straight plug & play.
But unfortunately the car gonna lose the High-beam with these plug & play LEDs.
Here are some photos :
Attached Thumbnails Halogen Headlight Bulb Replacement-led-1.jpg   Halogen Headlight Bulb Replacement-led-2.jpg   Halogen Headlight Bulb Replacement-led-3.jpg
Old Feb 10, 2015 | 01:19 PM
yuzone's Avatar
W213
Hello,
You can just follow the manual(page 118 ) for the H7 low beam blubs change
Low-beam headlamps/parking and
standing lamps (halogen headlamps)
X Remove the cover in the front wheel housing
(Y page 118).
X Turn housing cover : counter-clockwise
and pull it out.
X Turn bulb holder ; counter-clockwise and
pull it out.
X Take the bulb out of bulb holder ;.
X Insert the new bulb into bulb holder ;.
X Insert bulb holder ; into the lamp and turn
it clockwise.
X Align housing cover : and turn it clockwise
until it engages.
X Replace the cover in the front wheel housing
(Y page 118).
No sure how to adjust the bulb higher tho...
Old Feb 10, 2015 | 02:44 PM
SLK55 //AMG R171
I am almost finished completing an entire OEM LED/Bi-xenon headlight swap on GLAowners forum. I started the thread here: http://www.glaowners.com/forum/merce...w-project.html
I will be updating with pictures and necessary info soon. Just have one more issue to sort out, but so far, it has not been as bad as many might anticipate.
