GLB Class (X247) Produced 2020 to Present
fuse layout
Old Oct 18, 2021 | 07:11 PM
RA051523's Avatar
fuse layout
Is anyone able to furnish me with a complete fuse layout - where they are and what they do for a 2021 UK spec GLB 220 D please
also where on earth is the starter battery?
thanks
Old Oct 19, 2021 | 08:54 AM
Vladimir Livson's Avatar
2021 Mercedes GLB250 4Matic
Review the thread "Removing Sport sound".
09-16-21 post has pictures of the fuse legend document. You can find it inside the fuse box.
Both battery and fuse box are located on the driver side under your front hood. Box with red tab is your battery. Ground is the brass nut to the right. Fuse box is to the right of the battery.
Old Oct 19, 2021 | 05:53 PM
RA051523's Avatar
thanks
Old Nov 2, 2021 | 01:51 PM
vtek's Avatar
2021 GLB250
This is on a Canadian GLB 250
Old Jun 30, 2022 | 07:28 PM
tbirdvet's Avatar
GLK350
GLB250 fuse panel
Is there also a fuse panel in the cargo area. I wanted to do some accessory add in that area. Thanks
Old Jun 30, 2022 | 07:29 PM
tbirdvet's Avatar
GLK350
Is there any fuse panel in the cargo area of the GLB250? I wanted to add an accessory at that location. Thanks
Old Jun 30, 2022 | 07:33 PM
RA051523's Avatar
I found a small speaker (about 5cm across) in the footwell - if you lifted your foot up you would pretty much be on it.... I wonder if these are the speakers the sound comes out of?... there doesnt seem to be any sound from the audio system through them
If so it would be easier to just disconnect them.....
Old Jun 30, 2022 | 08:47 PM
There are 3 fuse boxes. One under the hood, one behind a carpet in the passenger foot well, and one in the trunk. Although I am not sure of the exact location of trunk fuse box.
Old Jul 1, 2022 | 08:38 AM
Serhan's Avatar
2021 Glb35 AMG (2013 GLK 350)
From Vtek's post above:
Old Jul 1, 2022 | 11:53 AM
RA051523's Avatar
what about those speakers???
Old Jul 1, 2022 | 12:55 PM
UK speck might be different. In US GLB250 does not have any speakers in the back unless you upgrade to Burmester system. Then you add stereo speakers behind second seat, subwoofer at the front row, and amplifier below trunk floor.
Old Jul 1, 2022 | 01:01 PM
RA051523's Avatar
no, you misunderstand, they are not in the back, they are in the front footwells directly above your big toe if you were to put your feet at 90 degrees to your stretched out legs
Old Jul 1, 2022 | 01:25 PM
There are no speakers in footwell on US models. You might be referring to a subwoofer, but you would need to upgrade to Burmester in US to get it. Our standard set up is 6 speakers. (4 in doors and 2 in "A" pillar). Rest of the Speaker Covers are fake.
Old Jul 1, 2022 | 01:31 PM
RA051523's Avatar
there only APPEARS to be a speaker in the drivers side...it's a bit difficult to get to when you're 63 and have arthritis
pic attached
Maybe I will disconnect it and see if it stops the childish noise
Old Jul 1, 2022 | 01:36 PM
I have to check it out and report.
Old Jul 1, 2022 | 01:38 PM
RA051523's Avatar
probably only there if you have the option Engine Sound System enable(Non AMG only)
* Enable the synthetic engine sound to be played through the speakers to make the engine sound sporty
Old Jul 1, 2022 | 01:42 PM
The fake sound option can be disabled via coding.
Old Jul 1, 2022 | 01:54 PM
RA051523's Avatar
Yeah, I asked my dealer to do it but they said it couldn’t be done…..couldnt be arsed more like 😊
Old Jul 1, 2022 | 01:59 PM
Apparently there is a guy in London "RJ" who is doing all the coding remotely for everyone on this forum.
P.S. I was wrong and I do have a speaker in the footweel. I never looked there nor I ever heard any sounds coming out from it.
