Interior Accessories
Since GLB is still a new model and very few accessories are available, I wanted to see what interior accessories other people bought for their cars.
Here are few I have done so far:
Trunk lower floor liner and net.
Center Console Shelf
Angle USB C cable
Angle USB C cable
I got the smartliner floor liner as I found it cheaper on Amazon as a returned item... Also I am getting the net... My previous one doesn't stay on. I put the spare tire between the smartliner and the MB floor liners, not straight but covers my other items also... I'll see net will make it more stable...
I got a sd card with usb-c for mp3's and the cd player for the cd's as below. Both are inside the center console connected to usb's and can be switched by the radio to external device by push of the radio button....
Benzgurl#1 (02-10-2022)
I got my net on eBay, but I changed plastic hooks it came with, with stainless steel carabiners. The net was popping out from cheap hooks it came with originally.
https://www.amazon.com/gp/product/B0...title_o05_s00?
Received 2,628 Likes
PFL205.064 with M276.823 (Oil pump solenoid defeated)
https://m.media-amazon.com/images/I/...AC_SL1500_.jpg
It is no name cd player, made in China. They have 2 versions. I bought the one in the link from Amazon as I didn't know if it would be working with GLB....It is much easier to return with Amazon. It works similar to car cd players, only hidden in the center console, sitting vertically next to cd's...
Power Inverter
I spent an hour in the Canadian cold trying to find the fuse box in the trunk... unsuccessful.
I ended up using the cig lighter temporarily. Luckily, the plug runs on ignition only and the inverter has an on/off switch.
Quite happy with this addition especially when I have to charge my laptop on the road.
Power inverter details:
300W - 4 USB ports (2.4A) - 2 AC outlets.
diggs718 (07-14-2022)
I cannot figure out why MB decided to eliminate sunglasses holder compartment in US version of 2021 GLB250. I believe it was there in 2020 model year. It was driving me crazy for a year and finally I gave up and purchased Sun Visor holder clip for glasses. It's not perfect but at least it right there when I need my glasses.
Here is the photo of the center console with the cd player and sandisk storage:
Here is trunk with the spare tire and lowered cover. I need to buy a solid cover above it, but it works ok like this:
I think the pictures are available on the amazon link posted?
I found one on Amazon and have been using it for a year now.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
I had one like this in my previous car, it was really nice and tidy.
here's my entry... a compressor coolbox that freezes down to about -10 degrees C....
I have 2 x 12V 20AH SLA batteries connected in parallel mounted under the boot floor connected via a standard split charge relay so they charge when the engine is running but isolate from the car completely when the engine is off - I tried using the car battery but it complains like crazy that the battery is discharged after a few hours (which it isnt)
The box takes around 4AH when running and zero when it has reached temperature so averages at around 3AH which will run for around 12 hours
....works for me ....mainly used for shopping
MOBICOOL MCF40 - 38 l Compressor Cooler, Blue/Grey, Cool Box 12/24 V DC / 100 -240 V AC, Mini Fridge for Car, Truck, Boat, Motorhome and Power Socket : Amazon.co.uk: Automotive
mounted on an aluminium tray I had made up in a local metalworking shop that runs on slidesI have 2 x 12V 20AH SLA batteries connected in parallel mounted under the boot floor connected via a standard split charge relay so they charge when the engine is running but isolate from the car completely when the engine is off - I tried using the car battery but it complains like crazy that the battery is discharged after a few hours (which it isnt)
The following 2 users liked this post by RA051523:
benz_driver (06-01-2024),
Serhan, can you tell me the part number of your floor mat please? I'm so sick of lazy part guys at dealerships telling me they can't find it. I have a 2022 GLB 250 but I can't imagine the boot tub is any different with your 35.
I have 2 floor mats actually. MB one came with the car when I bought it. If you lower your trunk, it doesn't fit. That is why I bought also one that Vladimir posted. It was also cheap as a return item in Amazon, since that one doesn't fit if you don't lower your trunk. So choose accordingly. I don't know the part number for MB mat, since the dealer installed it and threw the packaging. I found the MB mat on Amazon if you want to order it:
diggs718 (07-18-2022)
Mercedes Benz GLB X247 Trunk Cargo Tray Liner OE 2478140400
There are few options on Ebay, if you search for part number.
Maybe Serhan can confirm if this number appears on his cover?
P.S. Looks like a correct part number from German websites. For some reason US sites do not link this part to X247.
Thanks as well to you for replying Serhan. I wanted to get MB official tissue one because anything they have will be food safe/non-toxic, etc. because of stricter laws about this in EU. The ones we buy on Amazon for US market are guaranteed to smell like death and probably release cancer for years, at least usually in my experience.
I just got a travel pillow that nearly choked out my entire house... yet it is supposedly designed to sit in your car and bake all summer?!? No thanks.
Just curious if anyone considered or purchases simulated leather panel trim cover for the middle console? Not a big fan of piano black and the panel looks pretty good.
https://www.aliexpress.com/item/3256...26392e0ei0dhFG
Serhan (09-09-2022)
It looks good, but the leather pattern is not a perfect match... Still I might order to get rid of the dust on the piano black. I used simulated leather on cameras with no problems, enhances the look also... They make different patterns/colors with the cameras to match the rest as the leather area is smaller compared to a car... If it gets old, you can replace it easily using heat. One question is what happens the glue inside a car under the summer sun/heat... It might be worth to try...
