Loose multimedia USB port?
Supposedly mine just got replaced with a new one at the dealership. It connects snug like expected but I can wiggle the cable and it feels loose. It seems to be the assembly and not the connector itself.
Anyone know how to remove the port? I'm thinking of glueing it from the bottom. Maybe?
Looks like I just need to pop it out, but I'm afraid of breaking it.
As a side note. USB-C ports are notorious for collecting dust. You will be surprised how much lint is inside after a while. You can use fine toothpick to clean it. You can find plenty of YouTube videos on the subject.
First, thank you as always for your insight.
I also use a 90 degree angled USB C cable. The connectors of the cable and port is very tight so that isn't the issue but at that point cable/USB port connector are wobbly and moves around loosely.
The car USB c port seems to be loose and not seated or held in properly by the plastic trim. I was thinking of glueing or taping down the connector from the inside to hopefully limit the movement of the connecter.
so I have to pop off the entire center console to get to it? Or can I just pop off the small plastic that houses the USB port?
In case anyone is curious, the part number is 247-820-41-02
Looks like they replaced it with a remanufactured part 247-820-38-02-80? That part number is listed under "perform quick test". then it says, ”multimedia connection unit in front stowage compartment replace". So looks like they did replace it and it now works as designed....
So I guess I'll just have to figure something else out to keep it from moving around and disconnecting when going over bumps.
