GLC niggles, complaints and advice
Both my wife and I never seem to be able to lock the car using our thumb and only works with a finger. Bit temperamental and would ask MB to consider this for future models.
Greg
Didn't check the passenger door locking mechanism.
Greg
No issue with mine at all...very effective. Noticed that car will not lock from outside if key is inside.
Anyways, that noise is probably related to the HVAC system, like the blower.
Shut off AC and see if you can still hear the noise.
Crocodile writes...
There should be a recall on this issue!
OK guys so here is the latest on the ongoing saga of the juddering windscreen wipers. I suspect i am the most progressed with this issue with the dealer but if anyone else has any info to share that would be incredibly helpful.
So the following has been done to the car so far (over the course of a couple of months and several drop offs):
1. Polish the windscreen with a fine powder by a glass specialist and wiper blades replaced (was told it should be OK but subsequently it wasn't)
2. Polish the windscreen again with the same stuff by the glass specialist and wiper blades replaced (again was told it was tested and seemed OK but post pickup it wasn't)
3. Angle of wiper blades to the windscreen was adjusted by dealer (didn't resolve)
4. Mercedes Benz HO AU become involved and advise that the angle of the wiper to the glass needs to be measured using a special tool that can be ordered via spare parts. Angle is measured and found to be within tolerance. Was also given a bottle of MB Intensive Window cleaner which is like a glass polish that can be used occasionally (dealer suggested maybe every 6 months or so). This was just on Monday when i picked the car up again. At the time was told that all was fine and today i have already got juddering again.
Below are a couple of videos. First one is in normal speed and then one in slo mo. If you turn the volume up on normal speed you will hear it. Slo mo clearly shows the juddering.
https://vimeo.com/163115725
https://vimeo.com/163115759
FYI the dealer i've been working with is MB North Shore (Sydney).
Hopefully this is helpful for other owners. Guys i strongly believe we all have to keep pushing this with our dealers and MB. They are only going to take notice once we are all complaining.
Hope this helps.
I brought my GLC home on the 5th of April. It rained that day and several days after. Having read about this issue on mbworld, I was a little concerned.
It turned out that when my wipers were operating, they were whisper quiet and smooth. So the problem isn't inherent.
Al
