How to disable key fob.
Old May 22, 2016 | 12:55 PM
decorily's Avatar
GLC 300d 4matic
I am planning on keeping a spare key fob in the car in case I ever loose my key that I carry. Having keyless access and start I need the spare key to be disabled while in the car. Should I take the battery out or is there another way to temporarily disable it?
Old May 22, 2016 | 02:01 PM
JM-GLC's Avatar
2016 glc
Page 84 of the Operator's Manual says, "If you do not intend to use a SmartKey for an extended period of time, you can deactivate the KEYLESS-GO function of the SmartKey. The SmartKey will then use very little power, thereby conserving battery power". It then lists instructions on how to disable and re-enable it.
Old May 22, 2016 | 03:20 PM
decorily's Avatar
GLC 300d 4matic
RTFM!!
Old May 22, 2016 | 08:40 PM
fabbrisd1's Avatar
A gaggle of MB's
Please remember - when you re-activate the fob - you need to pull the Keyless Start button and use the fob to start the MB once like a regular MB - so that the MB "re-recognizes" the key - after you have done that once - then you can use Keyless-Start/Keless-Lock/Unlock with that key again...
Keep the beat !
Old May 23, 2016 | 01:08 AM
JM-GLC's Avatar
2016 glc
Under the Deactivating and activating SmartKey section, the Owner's Manual says:
To activate:
Press any button on the SmartKey.
or
Insert the SmartKey into the ignition lock. KEYLESS-GO and all of its associated features are available again.
Old May 23, 2016 | 10:24 AM
guido3's Avatar
2016 GLC300 4Matic
Here's your answer, I think:
http://www.benzblogger.com/2015/01/mercedes-benz-keyless-go-smartkey-on-and-off.html
Old May 23, 2016 | 12:00 PM
decorily's Avatar
GLC 300d 4matic
Originally Posted by guido3
This is indeed my answer!!
Now all I have to do is find a safe hiding place for the key in the car....any suggestions?
Old Oct 2, 2016 | 04:59 PM
Bernie51's Avatar
2017 GLC 4Matic
Smile
What am I missing? How would you get into your car if you lost the one key fob and have the other locked in the car?
Old Oct 2, 2016 | 05:57 PM
ec_nova's Avatar
E300, C63
you wouldn't, unless you have the app. This thread was about disabling a smartkey's transmitting feature, so as to preserve battery life of the key. All 2015 and up have this ability (if equipped with keyless go)
Old Oct 2, 2016 | 08:35 PM
Bernie51's Avatar
2017 GLC 4Matic
Smile
you wouldn't, unless you have the app. I presume you're referring to mbrace which is not available in Canada. I have no idea if mbrace or similar app is available in Ireland.
Old Oct 3, 2016 | 05:57 AM
decorily's Avatar
GLC 300d 4matic
My car can be unlocked online so in the event of losing a key I can simply unlock from my phone and access the key (hidden in car) enable it by pressing any button and start the car.
Old Oct 3, 2016 | 09:27 AM
Bernie51's Avatar
2017 GLC 4Matic
Smile
Thanks for the clarification.
