Ventilated Seats Does not Really Cool
Old May 26, 2016 | 02:58 PM
hoo's Avatar
hoo
GLC 300 4Matic
I really enjoy this GLC.
However, my Ventilated Seats Does not Really Cool and just found it out recently. I set it at the highest setting but only feel a little of cooling in the back rest and nothing in the bottom cushion. I also have a hyundai with vent seat, which I can clearly feel the chilling from bottom and back.
I took it to the dealer and they said it is normal and was designed this way.
Anyone with the vent seat has any comment?
Old May 26, 2016 | 03:05 PM
PeterUbers's Avatar
They are a poor design i have the same
They are intaking air from rear and smashing it in your butt
Ideally the air in back should be cold from the ac before they work better but they don't use actually air directly from the ac to blow on your body
Someone commented they worked better by creating space between your butt and the seat by using those beads on the seat like cabbies have
Old May 27, 2016 | 03:35 AM
decorily's Avatar
GLC 300d 4matic
Remember...ventilated seats and cooled seats are entirely different!
Old May 27, 2016 | 08:38 AM
SteveE400's Avatar
2015 E400 and 2015 GLK350
. . . and ours are "merely" ventilated.
I do find that mine make a difference, though. I don't find the back of my shirt soaked on hot days if I use them.
Old May 27, 2016 | 12:22 PM
hoo's Avatar
hoo
GLC 300 4Matic
Yes. But I am just very disappointed for not having the cool seat for a car at this price and this luxury level
Old May 27, 2016 | 06:26 PM
daffy1's Avatar
2016 GLC300
I had the same problem with my ventilated seats, especially the front passenger seat - I don't feel any change in temperature at all, even at it's highest...same with the heating seat system feature. I did have it check and apparently, it's normal and they can't do anything to improve it. My driver seat works better than the passenger seat. The service advisor's explanation is because there's more padding on the passenger seat to accommodate a lighter-weight passenger in order for the airbag to function properly. The MB mechanic compared my GLC300 with older models and found that the older models' vent technology has air blowing upward, but apparently the air vent on the new GLC300 is blowing downward like a vacuum so you don't feel the air as much. He wasn't aware of the change so he had to look up the manual, page 112-115 (seats) where it explains how the seating climate system is expected to work. Personally, I would prepare the air to blow upward so you can feel the temperature changing, rather than sucking it down like a vacuum. Do they really think by directing the air downward would make the seat feel cooler? Bottom line, it's a useless upgrade!
Old May 27, 2016 | 07:25 PM
jeffn23's Avatar
GLC300
I just sold an S500 with ventilated seats and therefore got that option on the GLC. I find that the cooling is more noticeable in the GLC than it was in the S500. Maybe because it pulls from the top I feel it on my upper back more or something like that. In any case, I find the ventilation makes a big difference and I have a black interior and live in the desert. I'm happy with it.
Old May 31, 2016 | 12:32 AM
TSchuettinger's Avatar
2016 volkswagen beetle
Do you feel heat at all with the heated seats? I didn't get to try them being that when I test drove, the weather wasn't cool enough.
Old May 31, 2016 | 12:59 AM
daffy1's Avatar
2016 GLC300
I do feel the heat on the driver side just fine but, not as well on the passenger side.
Old May 31, 2016 | 01:02 AM
Oh okay then the padding part makes sense. I expected the ventilated part wouldn't cool, just circulate air. Which is still something. I live in the hot desert and sweaty butts are common in the summer so it's still helpful.
Old May 31, 2016 | 08:40 AM
JEVA's Avatar
2013 BMW X6 - Soon to be GLC300 4M
The problem with this system in any car is the weight of your body compresses the foam/padding and the air channels collapse, preventing ventilation through them.
Old Jun 1, 2016 | 09:14 AM
hoo's Avatar
hoo
GLC 300 4Matic
But the system on my Hyundai works really well
For half of the cost. It is shame on MB.
Old Jun 1, 2016 | 10:40 AM
retguy's Avatar
240D,S550,CLK500Cabrio,E550,SLK350,GLS450,E450Wagon,C300Cabrio--all sold. Now CLE300 Cabrio, BMW X5
Every Mercedes I have had with ventilated seats has been the same. Poor effect if any; unlike GM cars where you get a real cooling effect. Mercedes are wonderful cars but do have some shortcomings.
Old Jun 1, 2016 | 11:17 AM
Lexus has the same problem. I googled "ventilated seats arent cooling" and not only did it pull up a few Lexus forums, but I also found out that ventilated seats and cooled seats are two totally different things.
Old Jun 1, 2016 | 01:05 PM
decorily's Avatar
GLC 300d 4matic
[QUOTE=TSchuettinger;6819861..... I also found out that ventilated seats and cooled seats are two totally different things.[/QUOTE]
Didn't need Google to find that out..... see previous posts in this thread!
Old Jun 1, 2016 | 01:12 PM
[QUOTE=decorily;6819997]
Originally Posted by TSchuettinger;6819861..... I also found out that ventilated seats and cooled seats are two totally different things.[/QUOTE
I've known ventilated seats didn't cool months before this thread...
Old Jun 1, 2016 | 01:30 PM
egalt's Avatar
2011 E350, 2007 CLK350
So...exercise, lose weight and eat better. Obviously the cooling system has a weight limit.
Old Jun 1, 2016 | 07:03 PM
sgmstr's Avatar
2016 GLC300 4Matic
It worked on my old Lexus and I'm pretty bulky. It had air ducts connected from AC going into the rear seats.
Old Jun 1, 2016 | 07:14 PM
Was it an LS?
Old Jun 1, 2016 | 07:33 PM
sgmstr's Avatar
2016 GLC300 4Matic
Was it an LS?
GS 450H. My wife's RX350 also had ducts.
Old Jun 1, 2016 | 08:00 PM
JEVA's Avatar
It has nothing to do with my weight...but thanks for assuming I'm a fat slob. The seats have foam in them, to which the air channels run through. Foam, by it's very nature, collapses which is what makes the seat comfortable, otherwise you might as well be sitting on a wood plank. When the foam collapses, the ducts collapse. Not all but a fair number. If you are light enough to not collapse the foam, then you must be a small animal.
Old Jun 1, 2016 | 08:56 PM
Okay so the ones I read about must of been cheaper, older models. The ventilated seats I know about are simply fans.
Old Jun 11, 2016 | 05:33 PM
MITCH1975's Avatar
2016 GLC 300
And sorry little fans they are. The other day I was looking under the seat just to check it out. For the bottom cushion there are 2 CPU fans that do the work, one on each side. I guess something is better than nothing. Definitely bigger fan for the back of the seat, that one I feel.
Old Oct 8, 2018 | 08:18 PM
HETPE3B's Avatar
Own 2005 CLK500, but drive 2011 Sienna :)
Folks, how to properly take the panel out that covers the presenter, seat belt and window motor?
Old Jul 10, 2019 | 02:17 AM
s.balushi's Avatar
03clk 320
Hi,
My driver side seat belt is stuck and i am looking to buy a used one. I am not able to find one on ebay, can any one suggest where to locate one. I am from Qatar.
Car details
2003 CLK320 w209
Front left driver side seat belt retractor
