Air Pressures?
Air Pressures?
Mercedes puts the maximum load pressures on the door jamb but has additional pressures for normal load on the gas tank lid.
Car was delivered from factory with maximum load pressure which for 20's is
F 35 R 42 Max Load
F 32 R 32 Normal Load
I think this was way to high but the normal load was on the low side so I set 35 all around, what are you guys running?
F 35 R 42 Max Load
follow the guide in the gas door...if my memory is correct, it calls for 32 all the way around when not heavily loaded. There's another thread or two on here on the subject.
Because they could sit in transit for some time it's better to over inflate them. If they were all at 32 and then lost some air over the course of the month(s) transport then that could damage the tires. Sticking them at 42 or so gives MB a bit more leeway!
Actually MB factory spec is 47 lbs for shipping, to prevent flat spots if the vehicle is kept in inventory for long periods. Part of the dealer prep is to adjust the inflation to the proper pressure - in the case of our GLC set to 32 lbs all around as per the gas door decal.
Understand the need to overinflate tires while vehicle is in transit. What I don't understand is the dealers inability to adjust tire pressure as part of pdi.
Like most everyone else here my tires were at 45+ psi the first time I checked them.
