AMG Grille in GLC 300
Thanks in advance!
Here's a link I picked up from somewhere around here, but I can't make any promises on fit, since I haven't tried it.
http://www.ebay.com/itm/fit-for-Merc...torefresh=true
Thanks in advance!
AMG Diamond Grille (either the Coupé and the 43AMG one) is 100% compatible with GLC300.
There are 2 versions: one for vehicles w/360° camera and the other for vehicles without that option.
Make sure you buy the correct version and buy an original one.
https://www.kunzmann.de/shop/en/tuni...ator-grill.htm
This is the 43amg version original. But you could easily buy it from your MB dealer.
Here is a photo of my GLC250D (same as the GLC300 but diesel) with the diamond grille.
I think you need to remove the whole bumper, it's not the easiest task.
DSG Tuning and here is the item #112325560754
You can tell them the vent bar color, silver or black and with or without the camera. Good Luck. ps I negotiated the price a little. Total delivered was $280.
Install in reverse order.
The center piece with the emblem is a twist lock. There are two tabs that lock it in from the back. Once the locking tabs are released it is a slight turn/twist to release it, you will be able to see the slots for the emblem once the grille is removed.
I hope that helps.
Also, it will take some creativity since they are awkwardly shaped, but to remove the air dams, pull out on the grill slightly to get them past the cross bars and towards the center. Keep pivoting them around and eventually you'll find a position that gets them out from behind the grill.
Once you've got all of the tabs released, it's pretty easy to wiggle the grill out.
It's a tight space, and I scraped my hands up a bit since there's a bit of sharp metal around, but it's doable.
What would the part name be? I am on www.mbpartsonline.com to check for the diamond grill that would fit my GLC300 but I don't see it when I search. Was just curious how much the dealership would charge vs ebay or other site.
I'm really loving the diamond grill look especially my car has the AMG body styling.
I have a white GLC300, what do you think of a matte black diamond grill ? hmm
This is for the 360°Camera
I would have thought the only body part differences between a sports package and GLC43 is the front diamond grille, the chrome edged fins at the "foglamp area", rear wheel fenders, the double dual tip exhaust, gloss black window trim (even without the night package).
As far as I know, the rear spoilers are the exact same ones.
