Illuminated Star with Distronic?
I found this listing:
http://www.ebay.com/itm/LED-MERCEDES...kAAOSwqk1Zd5Zx
I was wondering if you guys think it'll work while still providing the distronic features? Any thoughts? I really love the look of the illuminated star at night time .. just looks so cool!
Thanks!
Thanks!
Something doesn't smell right here! Maybe a MB service mgr can shed some light on why an aftermarket version couldn't work.
But, it's only $120 bucks so maybe it's worth that much to you to try it? I'd be more concerned if you'll actually get the Star after you order it. Remember, if something seems too good to be true.......
I have actually purchased this illuminated star for my 2014 GL with distronic plus. https://www.ebay.com/itm/Illuminated-Car-Led-Grille-BlLED-Logo-Emblem-Light-For-Mercedes-Benz/122316514939?ssPageName=STRK%3AMEBIDX%3AIT&_trksid =p2057872.m2749.l2649
and after installing it got 3 fault messages - attention assist, distronic and blind spot assist. All were disabled. So i had to remove it. But after looking into construction of the star I think that what blocks the distronic signal is the led lights assembly piece in the center of the star. What I have in mind is to remove this led assembly but keep the plastic grooved ring that spreads the lights around and test it again. If distronic signal can go thru the next step would be to enclose led light module in a separate small plastic box that could be attached somewhere on a side behind the grill and transfer the light from the source to a grooved plastic ring with a set of fiber optic cables, possibly using 2 or 4 for even light distribution. Each cable would attach to the grooved ring from behind thru a small drilled hole. Can be fixed in place with a silicone.
This is just to describe the concept, probably you can recommend better execution. What do you guys think? I would love to have a illuminated star on my GL but don't think have enough DYI skills to pull it. Perhaps this is something we can discuss to pull together?
https://youtu.be/VO_r30Z4fOo
I am currently customizing an illuminated star grill to work with Distronic Plus. 1st phase is completed by testing the assembly on the vehicle with the Distronic enabled. It worked. No message on dash. Next phase is to test with illuminated star lit, but have to wait for grill comes back from custom fitting the clear illuminated star assembly to the grill and mount the chrome Mercedes Star....will keep everyone posted.
Glad to say that yes it is working on my 2012 S550 with Distronic Plus. I wanted to give it a few more days since I haven't driven it to long on the highway. I did activate the DistronicPlus feature on local back roads and it gave no error message as of yet. Usually it gives the 3 error messages within minutes of driving with the other Illuminated stars, but nothing yet with this one. Like AkTech said, its all about what blocks the signal.
would you mind to share details? Where did you relocated the center electronics piece from the back? What else has to be customized?
A330PYLT
A330PYLT
A330PYLT
