[DIY] How-To: Hardwire Dash Cam Install GLC X253
Old May 9, 2020 | 06:18 PM
gqboy's Avatar
GLC 300
Originally Posted by Xtrema
Do you have a 2020?.
I have a 2017.
Old May 15, 2020 | 11:15 PM
oskidbear's Avatar
2019 GLC 300 4matic
I used 206 & 216
In response to gqboy's post,
I recently installed a Viofo A119v3 in my wife's 2019 GLC 300 4matic & used add-a-fuses at locations 206 & 216 (5A at both, but could probably replace with 2.5A or 3A) to enable the use of parking mode.
The Viofo hardwire kit requires connections to both switched power (216) & constant power (206) to work properly.
I need to clean up the excess wiring behind the fuse panel cover, but the dashcam automatically switches on when the car starts, turns off shortly after we park, & would go into parking mode if & when it's turned on.
Old Jun 19, 2020 | 12:39 PM
tjerkpolle's Avatar
clc 350e
Hi there,
I also want to install a Viofo A119v3 in my 2016 GLC 350e.
There is a 5A Fuse in Position 216 which is switched power I can use.
I also need constant power, but there is no fuse at the position 206. I do not have a analog clock.
Is it also possible to use for example the pos 205 (Ignition) or is that not very wise?
Or 204 Diagnose?
already found it. It is just a spare fuse. I can use it !
Old Jun 19, 2020 | 02:00 PM
tjerkpolle's Avatar
clc 350e
Other Question: I have the Viofo hardwire kit. What is the best Voltage Setting for the hardwire kit not to drain de GLC battery?
Old Jun 19, 2020 | 09:24 PM
oskidbear's Avatar
2019 GLC 300 4matic
I use the highest voltage setting
Hi tjerkpolle,
I, too, have the Viofo hardwire kit & have set mine to the highest voltage setting (12.4V) so the battery won't be forced to run below its nominal 12V output. This should prevent excessive drain.
Old Jun 21, 2020 | 08:20 AM
tjerkpolle's Avatar
clc 350e
Can someone post a picture how the driver fuse compartment looks after hard wiring your dashcam?
Old Jun 28, 2020 | 12:47 AM
  #32
oskidbear's Avatar
2019 GLC 300 4matic
Hi all,
Here's what the driver's side fuse panel looks like on our car (apologies for the large photo from my phone):
Old Jun 28, 2020 | 11:22 AM
  #33
tjerkpolle's Avatar
clc 350e
Hi Oskidbear, thanks for your help. I use the same positions, but I think hou have the right fuse tap (position 216) the wrong way around?
I measured that the 12V is on the left side from fuse 216. So with the fuse tap positioned as you pictured the fuse does not work?
Am I right?
Old Jun 28, 2020 | 08:07 PM
  #34
oskidbear's Avatar
2019 GLC 300 4matic
I used post #1
Hi tjerkpolle,
When I installed the add-a-fuse to position 216, I followed a photo from HeroAychillus's post (#1) for orienting the fuses.
It seems to work, as the camera starts up when we start the car & parking mode did run correctly when I tested it (though I should test it again).
Old Jun 29, 2020 | 06:14 AM
  #35
tjerkpolle's Avatar
clc 350e
@oskidbear Yes, but the way I positioned the fuse tap it also works.
@oskidbear @HeroAychillus Guys maybe I 'am wrong.
But I measured the Fuse position 216.
I measured without the fuse/fuse-tap in position the feed is on the left side.
In the pictures/schemes I also post you can see how the fuse tap works.
I think the fuse from the fuse tap in second position for the dashcam does not work. I think if you pull out the fuse from the fuse tap you still get signal with ignition on and that is wrong??
Old Jun 29, 2020 | 11:07 PM
  #36
oskidbear's Avatar
2019 GLC 300 4matic
Hello tjerkpolle,
Regarding the correct orientation of the add-a-fuse in position 216,
You could be right. I'm definitely not an expert on electrical systems.
When I installed my add-a-fuse at 216, I used the following to guide me:
  • photo from post #1; &
  • maintaining the same physical orientation of the original fuse from 216 as if there was no add-a-fuse (current rating reads upside down when installed; does this matter for a fuse?)
Is this incorrect? It wouldn't surprise me if it was, but the system works so far. I'm definitely not the right guy to ask why...
When I get some time next weekend, I'll pull out the fuse from 216 to confirm whether I still get power to the camera. Should I pull the original fuse from 216 or the one for the camera?
Old Jul 1, 2020 | 06:32 AM
  #37
tjerkpolle's Avatar
clc 350e
Hi, maybe an other forum member can help here?
You should pull out the fuse from the camera. When you still get signal something is wrong.
Old Jul 4, 2020 | 12:01 AM
  #38
oskidbear's Avatar
2019 GLC 300 4matic
Camera did not turn on when fuse was pulled
Hi tjerkpolle,
I got a few minutes today to pull the camera fuse from the add-a-fuse I installed.
Before I removed the fuse, I pressed the start/stop button to turn on the car & the dashcam turned on by itself, as it normally does.
After pulling the fuse, I pressed the start/stop button to turn on the car & the dashcam did not turn on.
Still not sure what it means, but the dashcam works the way I want it to.
Old Jul 28, 2020 | 08:21 AM
  #39
Arras's Avatar
MB GLK
Hi,
I have my Xiaomi 70mai Dash Cam Pro installed this way in my 2020 GLC SUV. This camera has a small battery inside so it needs power after ignition. When a car is parked camera is monitoring surround and records collisions and events on parking.
The camera was connected by an MB workshop so you can be sure that you can use this fuse slot. It is hard to find a fuse map for GLC2020. I don't know a slot number. I attached two pictures. It is a passenger foot fuse box.
I ordered the second camera for my friend. I put a cable to the fuse box first and surprise - GLC 2019 has a different fuse box.
I saw earlier posts in this thread but I have already a wire in a passenger foot box. I would like to avoid removing it on the other side (driver instrument panel).
Is there any fuse in the foot passenger box (GLC 2019) which I can use to connect a camera? (powered after ignition)
Old Aug 7, 2020 | 06:27 AM
  #40
mtbase's Avatar
2020 GLC 63s
Hi Arras
I think that fuse slot you use is for Airbag systems, It's probably not safe to use that slot.
Old Aug 14, 2020 | 02:40 PM
  #41
Arras's Avatar
MB GLK
You are probably right. However, it was installed by the MB workshop. It seems that they don't know what they do.
Could you place a picture with a description for all fuses, please? I didn't receive this instruction with my car.
Old Oct 10, 2020 | 11:40 AM
  #42
Byreman's Avatar
GLC 350D AMG
Just a short message to say thanks for taking the time to post this thread. Hugely useful and I can confirm the fuse box drivers side (uk car) was fuse 216 as mentioned. Fuse to glove box led. I fitted a Blackvue DR900x 2ch unit and it was so easy to fit in the GLC 350. In my Range Rover it was a bit of a pig to fit the same unit.
Rear cam was so easy too.
i can post pics if required. But huge thx again saved me so much time with the fuse numbering.
Old Oct 18, 2020 | 08:49 PM
  #43
Bmo Pete's Avatar
2024 GLE 580
Do you have a 2020? If you do, I don't think the fuse map matches. It's completely different than this on my GLC2020 GLC43.
The only 2 I want to touch are 213 and 211 and both are always on. And I can't even be sure it the old 2017-19 map is valid here any more.
If anyone have access to the 2020 fuse map would love to have a copy here.
Not really entertaining passenger side fuse box, the wire run isn't as clean from there.
This pic is like our 2020; there is nothing there in the 216 slot, not even a usable slot to stick a fuse in. Now where to tap for a radar detector that’s not hot?
Old Sep 2, 2021 | 10:17 PM
  #44
Barbaris's Avatar
2020 GLC43
for folks with GLC 43 2020. I tested and could not find any fuses with switched power in front left or right fuse boxes on my wife's GLC 43 2020. Very frustrating, I ended up pulling wire to the trunk. Also I was not able to use mirror tap wires - positive wire was always on.
Old Sep 11, 2021 | 11:28 AM
  #45
Barbaris's Avatar
2020 GLC43
I installed my dashcam with rear camera and it was quite a project.
I took a bunch of pictures if it helps someone.
https://imgur.com/a/NVGfklH
I decided to wire to the rear fuse box as they seem to not have ignition/switched fuses any more after 2020 refresh. Fuse 216 is gone as well on front.
I also decided to wire on bottom alone the seats - it did require me extending power cable but fortunately USB cable for the rear camera was long enough (23 ft). I did not want to risk it wiring over side air bag.
Mission accomplished but with researching, reading, watching tons of youtube video, picking stuff on amazon etc. it took me over 30 hours. I think next time I am just going to pay for this as it was too much "fun" for me.
Mirror tap does not work any more like it is used to be because power from mirror won't shut off even after 30 minutes after ignition is turned off. But I learned that my Uniden R3 has a feature to auto shut off itself after 1 hour if GPS speed is 0. If I knew about this upfront, I would wire radar detector to the rear fuse as well when I had all the panels open but I do not want to think about doing this all over again So if you have 2020 and later, you might want to hard wire both dashcam and radar detector to the rear fuse box at once.
Old Sep 20, 2021 | 09:32 PM
  #46
jbaruch's Avatar
2021 GLC63
I wonder how bad it is to leave a radar detector on always on. Granted, the power should be manualy disconnected for long breaks, but other than that, driving the car every day, I am not sure it's a big deal.
Old Sep 22, 2021 | 10:56 AM
  #47
Bmo Pete's Avatar
2024 GLE 580
I did not know that about the Uniden R3 (auto shutoff), I have one in each car; will have to test that, though I already mirror tapped the Audi.
Old Sep 22, 2021 | 10:59 AM
  #48
jbaruch's Avatar
2021 GLC63
I've learned about it 2 days ago. It works fine. Goes off after an hour of no movement according to GPS or no GPS signal. It's annoying to turn it on every time, but I guess it's less annoying than the rear fuse box wire
Old Feb 15, 2022 | 11:40 PM
  #49
beejonnybee's Avatar
Fiat 500
Hey guys, what size (type) of the fuse tap do I need for tapping into #216? Thanks
Old Feb 12, 2023 | 04:24 AM
  #50
Impasta's Avatar
2021 GLC63s Coupe
i'm curious, is it not possible to use "seat heating 305/306" or "exterior mirror function 302" or "sunroof, tilt 312,317" as a switched source for a dashcam instead of running wire to the rear?
