Active Assists - Your experience and recommendations
- Active Brake Assist
- Active Brake Assist with Cross-Traffic Function
- Active Parking Assist (Parking Pilot)
- Active Distance Assist DISTRONIC (Distance Pilot)
- Active Steering Assist
lane keep assist - this also helps reduce fatigue, and works pretty well. I found recently that all you really need to do is lay your hand on the wheel and it will not warn you. i do wish you could keep your hands off for more than 15 seconds, that would be really cool.
these two features for me make long highway drives much less tiring.
I like the idea of the braking options, but haven't had to use them fortunately. The active parking assist is neat, but I'd be highly sensitive to the price, as parking manually is a whole lot easier with the 360 camera (also standard here).
I think the disctronic is fantastic. Once you're used to it, cruise control in traffic without it is a pain, such as in our B200. Highly recommended.
The active steering assist is a bit marginal. I find that it makes the steering light. It's useful in a couple of situations. It does make it easier to steer in a dead straight line for long periods, despite the need to have your hands being detected as being on the steering wheel every 15 secs. If your attention has momentarily wandered (naughty) coming into a slight turn in the road then steering assist with alert you to this by starting the turn.
Note that this is different to active lane-keeping assist (at least it is in this country), which I find a pain and mostly leave off. If it detects that you've strayed from your lane then it brakes slightly and jerks you back into your lane. I find that country driving is tedious with this turned on, but it can be useful on highways (interstates / autoroutes) and the other driver finds it useful. On balance, although they have their uses, I'd only choose either of these steering options if they were relatively inexpensive.
The important thing to bear in mind about Parking Assist, at least in the US, is that without Parktronic you don't get Parking Sensors, if that matters to you. Parking Assist also gets you the 360 camera, that I perceived as sort of gimmicky, but I find I love it in parking lots....shows exactly where curbs are to keep from scrubbing your wheels.
Haven't even tried the Parking Assist function yet. I can parallel park fine, but I'm sure I'll use the 360 cam to help me keep an eye on other cars/obstacles. As far as I'm concerned, Parking Assist just happened to come with the Parking Sensors and 360 camera.
I love DISTRONIC Plus and it does a nice job. Makes traveling on interstates much less tiring and aggravating as the flow of traffic changes. My one complaint, and this is not the cars fault, is I find my car slowing down abruptly as I close in on a vehicle, as ajmtbm described. Without it I was always aware I needed to change lanes and go around the car in front of me. Now they kind of sneak up on me. I just need to pay better attention. Intervening by braking, if you need to, is not that big a deal and it's easy to resume, just like old cruise controls.
Be sure you understand the difference between Active Steering Assist and Lane Keeping Assist. Bips analysis is spot on....I think each driver figures out what works for them. Active Steering Assist is actually part of the DISTRONIC Plus feature and makes driving on highways almost effortless. Lane Keeping Assist Can be rather annoying as Bips described and I would only plan on using it on longer, straighter roads when I knew I wouldn't be taking inside curves kind of tight. The intervention is annoying and, in a way, kind of dangerous given the stern braking that occurs to get you back in your lane. But I believe you can turn the braking off and just have the steering wheel vibrate.
While it's good to understand what each feature in a package does, you just need to decide what you HAVE to have. If Active Cruise Control is important to you, then you need to get the Premium Driver Assistance Pkg....the other stuff just comes with it. Same with the Advanced Parking Assist Pkg, if you want parking sensors, you have to get that pkg. The Advanced Parking Assist just comes with it.
No need to worry about each individual feature. Just figure out what you've GOT to have on your car and get the correct packages that include those features.
The lane assist sometimes "warns" you if you try to hug the outside of the lane while passing big semi trucks..but otherwise we love it.
In comparison to Telsa's autopilot, this doesn't even come close to what Telsa's offers. Tesla's can drive fairly reliably on the highway (with curves) with very little input from the driver.
I have opted to use it primarily once I get on the highway and then plan on staying in lane. If I am changing lanes etc, then the system does still work, but I find it easier to do it manually as I then have more control.
I would definitely recommend getting this.
you can turn steering assist off and have only active cruise but not the other way around
if only that applied to above 20 mph
or like the E class one minute at any speed - that would be awesome...
- adaptive (as the name suggests) adapts to traffic speed.
With other words:
- Adaptive: you set your cruise control to a specific speed and when the car in front of you is going slower than what you had set your speed to your car will slow down and not rear-end the car in front of you. It will follow at the same speed as the car in front. When your lane clears your car will speed up to the speed you had set it to.
- Standard: you set your cruise control to a specific speed and when you catch up with slower traffic you have to apply the breaks yourself, otherwise you will rear-end the car in the front.
