GLC300 Spare Tire Options
Old Feb 5, 2020 | 05:04 PM
DanD.'s Avatar
2018 GLC 4MATIC
Originally Posted by Xbowguy
Where did SteadyRover get his spare? any info to pass on?
The spare tire picture above for $200 is from 2020 GLC configurator, its a new option
Old Feb 6, 2020 | 08:24 AM
aweber1nj's Avatar
2020 GLC, 2022 C
Yeah, I wonder if that is a factory-order-only item? I don't see why it would be, but I've heard of such nonsense before. (I.e. NOT dealer-installed)
Still hard to believe that no dealer can identify the parts!
Old Feb 6, 2020 | 11:39 PM
Daniel6L's Avatar
W220
Browsing the dealer order guide unfortunately it looks like it is a factory option and not even a port installed option. Maybe it has to do with the different trunk liner they use?
Old Feb 24, 2020 | 10:33 AM
lfung109's Avatar
2020 GLC 300
Hi, so the trunk (broad cover) closed perfectly right?
Old Feb 25, 2020 | 02:55 AM
Daniel6L's Avatar
W220
Here's a picture of the factory spare. It comes with nice white gloves tucked in the side to not dirty your hands while changing the wheel 😂
Old Feb 25, 2020 | 08:26 AM
SEC1939's Avatar
2015 E 250, 1999 BMW M Roadster, 1939 International Harvester, 2023 GLC
it may have to do with rear collision specifications. With a spare you get the strength (absorption) of he tire and rim. Without they may have to change the metal stamping profile to achieve similar results, thus a non dealer install.
Old Feb 25, 2020 | 09:47 AM
  #32
mpalsal's Avatar
Daniel, are there numbers on the tire and the rim? Usually part numbers and tire size.
MP
Old Feb 25, 2020 | 12:50 PM
  #33
BCB5's Avatar
GLC300
Hi there,
Has anyone replied to this or have you found a solution? I have a 2016 GLC300 and 19 inch tires. I am also in need of a spare.
Thank you
Old Feb 25, 2020 | 01:08 PM
  #34
lfung109's Avatar
2020 GLC 300
that's hella big!
Old Feb 26, 2020 | 08:31 AM
  #35
Daniel6L's Avatar
W220
MP
I don't see part numbers on it but the tire size is 145/80/R19
Old Feb 26, 2020 | 09:28 AM
  #36
mpalsal's Avatar
thanks Daniel, several numbers are usually stamped on the rim, kind of hard to see, but under the light you can see it. They can be on either side.
This will be extremely helpful for those of us who want to order them.
MP
Old Mar 6, 2020 | 07:57 PM
  #37
jimh6's Avatar
3er
Huge thanks to Saber for researching this. I ordered a space saver spare and jack kit with compressor from a 2015 GLK350. Fits perfectly under the floor of our 2016 GLC300 4M as shown above.
It came from ”okautopartsms” on eBay. I contacted them directly and they listed it for me. $320 shipped with tax
https://okautopartsms.com/
1-800-748-7539
Now, to get those Conti DWS 06’s in 255.55.18
Old Mar 7, 2020 | 10:02 AM
  #38
mpalsal's Avatar
1-800-748-7539
i went a similar route but with spare and Jack kit coming from 2016 ML , $330 shipped from an EBay seller. Fit perfectly.
I think the factory one will become available in the future once more 2020 GLCs are on the street. We just have to check in with dealers from time to time.
Old Mar 13, 2020 | 06:20 AM
  #39
Xbowguy's Avatar
GLC 300 suv
Good Morning guys,,,,
After calling several salvage yards in my area... there are no 18 inch MB spares available. I have a 2019 GLC 300 suv 4matic base model ( not the sport ) with stock 18inch run flats , several of you purchased the ML350 spare A1644000002 18inch compact spare..
May I ask for those who did on their 2019 GLC 300 suv to verify please that tire size and part number , does it fit under the cargo lid , what version of MB jack did you buy? they're are several kinds some are scissors type with a flat pad or pad with a center pin
and then there's the one that lifts up on an 45 degree angle with a white plastic lift adapter... and now to the lug bolts..... the ML350 are M12 x 1.5 but the GLC300 are M14 thread..
anyway Before I purchase a NON returnable tire from Ebay I would like to verify the fitment
Thank you very much,
Xbowguy,
Old Mar 13, 2020 | 09:24 AM
  #40
BlackGLC's Avatar
GLC300 4 matic
Mine is a 2017 with 18" tires, but the info below might be useful:
-the A1644000002 fits under the cargo lid
-if you can't find that part number, try searching using interchange p/n 560-85015 (this sometimes returns more results - it appears to be the number commonly used by salvage yards for this spare)
-I bought the 166-580-69-00 Vehicle Tool Kit from MB online - includes the jack. You may see that the product page pictures two styles of jack - I received the scissors type.
-and 5 of these: 000-990-83-07 Wheel Bolt to fit with the spare
Old Mar 13, 2020 | 10:09 AM
  #41
threeMBs's Avatar
Only MBs - the best or nothing
All MB's SUV (except for 2020-on GLE/GLS which now use 15mm bolts), including all generations of ML350, use M14x1.5 bolts (not 12x1.5).
Old Mar 18, 2020 | 05:42 PM
  #42
Xbowguy's Avatar
GLC 300 suv
Xbowguy,
Well I purchased a MB pare tire(ML350 series) A1644000002 and a Jack tool kit from MB they are both shipped.. once I get them, I'll update on fitment... ( i hope it fist like the others have said)
Now I need 5 short lug bolts..... but I'm confused on size.. ML350 specs called for M12-1.5 but the my 2019 GLC 300 says lug bolts are M14. M14-1.5 size are hard to find.. ???
Old Apr 13, 2020 | 07:17 AM
  #43
Xbowguy's Avatar
GLC 300 suv
UPDATE:
sorry for the late update and not able to post pics but.. I can confirm that the retro fit spare tire parts I purchase DOES indeed fit my 2019 GLC 300 BASE suv with stock 235/60/18 tires..
1. compact spare A1644000002 155/80/18 fits below the cargo hatch and latches , no interference with front or rear rotors.. the short steel spare M14 1.5 23 mm lugs bolts fit they do not go threw the rotors to interfere with parking brakes..
2. OEM scissors jack worked find on solid concrete surface I did add (2) 2x4 1 foot pieces to my kit for soft surface conditions...
Thank you to all that have researched and passed along this data I plan on keeping the GLC for as long as I can.. as soon as the Run Flats crap out i'm off to Costco to get conventional tires in the future...
Old Apr 13, 2020 | 10:37 AM
  #44
SteadyRover's Avatar
2017 GLC300, 2020 E450 Wagon
Thank you for sharing
Old Jun 20, 2020 | 11:49 AM
  #45
DanD.'s Avatar
2018 GLC 4MATIC
UPDATE:
Thank you for taking time and share this information , just quick question
Is it really 80 in size of A1644000002 155/80/18
Everything what I could find T155/90/18
for the part A1644000002 ? Thank you.
Old Jun 23, 2020 | 06:49 AM
  #46
Xbowguy's Avatar
GLC 300 suv
Dan,
My apologies it is indeed T155/90/18 I think the A1644000002 might actually be the steel rim part number but it still leads to the over all spare tire on google search.
Look locally at salvage yards that have ML350's your save a little I got mine off of Ebay free shipping $105.00 unused off a 2015 ML350 Take your time in searching.,, make sure you get the actual tire pictures before you buy it verify it's condition.
Good Luck
Xbowguy
Old Jun 23, 2020 | 01:07 PM
  #47
DanD.'s Avatar
2018 GLC 4MATIC
Dan,
Good Luck
Xbowguy
Thank you for checking.
I just bought one of ebay, looks like diameter is in the spec with original 19in rims.
I really hope it will fit under the lid, will report back when its get here.
Old Jun 23, 2020 | 05:39 PM
  #48
Xbowguy's Avatar
GLC 300 suv
Attachment 425634
I assume you're driving GLC300 SUV mine is 2019 It will fit... I turned my upside down inner wheel facing up, slide it under the metal tab in the middle back of cargo area. the lid will close flat I had to push down with hand palm with some pressure.. the latch sometimes catches and sometimes don't but the lid fits flush as it should my tire doesn't bounce around or knocks up the lid.. but I'm driving off road on bumpy roads.. you should be fine clean it up good wipe it down with some UV spray ( 303 areospace) toss a pair of gloves in with your jack tool kit..
Old Jun 23, 2020 | 05:49 PM
  #49
DanD.'s Avatar
2018 GLC 4MATIC
I have 2018 GLC 300 4MATIC, there is fuse box on the right side which could be on the way, I saw some posts people were talking about EU vs US + Model year adds variances, I hope you are right and it will fit, the worst case lid will stay ajar and only if I travel too far
I bought this kit I bought this kit
+ MB jack and some other tools.
Old Jun 30, 2020 | 02:22 PM
  #50
DanD.'s Avatar
2018 GLC 4MATIC
Hi All,
Thank you all who provide feedback, because of all of you, I was able to get all and its does look good, so now is my turn to provide the feedback.
It does fit under the lid with other junk no issues.
Here is my setup,
Spare tire
MB Vehicle Tool Kit
Part #1665806900
GSPSCN Portable Air Compressor Pump Dual Cylinder Heavy Duty Tire Inflator with LED Light,150 PSI 12V Air Pump with Tire Repair Kit and Toolbox for Auto,SUV,Truck Tires etc https://
http://www.amazon.com/dp/B07GJND1PX/..._Ke4-EbTTG2C3M
Some pictures
Attachment 1
Attached Thumbnails GLC300 Spare Tire Options-photo158.jpg   GLC300 Spare Tire Options-photo981.jpg
