Any aftermarket mudflaps out there? Mercedes says no OEM for this vehicle!?
). Once it pops on, you will know it. And I recall, it popped in so nice, that they sat in place without putting the push pins and screw in. It got me at first too, but after forcing it slightly, fit like you see in the pictures. They are pretty flexible, so it should be easy once you try to line up the holes. If you still can't get them, I suggest taking them to a mechanic. Good luck!
That picture shows exactly what I am talking about. You almost got it on man! Push that corner in until that hole lines up with that screw. Yes the flap will flex a bit, but that's how they fit against the trim like a glove. Trust me, it will go, and "pop/slide" in and on that ledge and the hole will line up pretty much dead on. That lip on the mudflap will settle inside that lip on the fender liner you are leaning it against. Look at the below picture again carefully with your rear passenger flap in your hand. Exact same flaps man, I promise. I circled the two screws and where they go, your just not fitting them properly. Push that sheeet on like a boss! I hate to see you struggle, and it's not really the "Chinese vendors" fault. Three minutes in the garage and I'd have you on your way man. Stop by
This is my GLC 43 with the rear lowering links adjusted as short as possible, and the button in the cargo area that lowers it another inch or so for easy loading pushed. I would say lowered 4-6" total in this picture, with 2" of the rear tires(295/40/18) tucked in the fender, and that is as close to the ground as I can get them. I obviously didn't leave it this low, but I've never rubbed them on anything, or even came close while driving. It's lowered maybe an inch or two from OE all the time.
I am not comfortable drilling hole to the molding. How deep should I drill? Is it metal underbenth?
Is this listing for OEM and fit on a GLC300 with AMG line? It shows both front and rear with matching part# as posted above?
https://www.ebay.ca/itm/OEM-Mud-Flap...UAAOSwcxVax4x3
I like how the rear flap has the GLC word on it. It looks OEM for a not OEM accessory, Can you send me link of the ebay seller that sells it? Thanks.
He was pretty quick to send out a second set of rears but they don't fit either:
My photos may be inadequate as they do not show the clip locations but the second set are actually installed with two clips and the 10mm screw from below. carpart777 is checking with his supplier for a third set. Just thought I'd see if @4npower @linus69 @Rmlasalle have any insight for me....
