Comfort Mode Doesn't Shift to 1st Gear at stop
I'm not sure if this is just me or a common thing. But driving in comfort mode, once I come to a complete stop the car doesn't go to 1st, It only goes as low as 2nd gear. I am bringing it into the shop next week for A1 service so I wanted to make sure this is common behavior or abnormal.
Thank you!
Thank you!
It's normal
you won't get 1st gear unless you go to manual mode or sport mode.
The 9G has a very short first gear. The main benefit of having more gears is that the lower gears can be kept short for acceleration while still having taller gears available for fuel efficiency once cruising. The ratio spread is huge on the 9G. The first 6 gears are your normal driving gears, with 6th gear being direct drive, but then it still has 3 overdrive gears for fuel efficiency. Most regular MB models drive off in 2nd gear while in Comfort. Newer AMGs with the 9-TCT and 9-MCT always drive off in 1st gear for a better response.
But to start in 2nd gear the engine needs to make enough torque. To the person above with the 250d, it's not the peak torque that matters, it's the torque off the line, which is quite low in a 250d. To make the peak torque your engine needs boost from the turbo. W/o boost all you have is a small displacement. Small displacement diesel engines are dogs below boost rpm and need a lower gear ratio to start off. You need to compare the torque curves, because ICE don't make instant torque like electric motors.
Once the engine runs in and adpot to your driving, it will eventually always start at 2nd gear from a traffic stop unless you put it in park gear. The 2023 A250 loaner that I got with only 1K starts at 1st gear from traffic stop and it is very slow and tough start every time.
Actually, it's easily overridden by throttle action: give it enough gas and it starts in first.
Thank you!
Thank you!
