GLC 2020 Dash Cam Installation
Old Jan 29, 2020 | 10:32 AM
terrymac999's Avatar
Mercedes GLC 300d
Hi Gents
i have just purchased the above UK Specification vehicle. I removed my Nextbase Dash Cam from my previous C Class 220d
i installed the dash cam today and run the wiring into the drivers side fusebox on the end of the dash. This is where my previous camera got its power from of a 7.5A fuse which was on a piggy back fuse holder fitted with a 3A fuse
Camera powered up fine but on looking the vehicle dash cam remained powered up. I tried all fuses in this fuse box then rigged up a flying lead and tried fuses in the boot and also in the passenger side footwell fusebox
All these fuse remained live when I locked the vehicle. The only fuses I haven’t tried are in the engine pay, I did not try any of the micro fuses as I didn’t have a suitable adaptor
Any help in locating a suitable fuse which powers down the camera on locking the vehicle would be appreciated
regards
Terry
Old Jan 29, 2020 | 10:51 AM
aweber1nj's Avatar
2020 GLC, 2022 C
I am 99% certain all fuses in the PASSENGER side are always live. The driver's side should have some that are switched to ignition. Did you turn the vehicle off AND open the driver's door when you checked the circuits? Many of the switched ones stay live until the car thinks the driver has exited the vehicle (by detecting the door open/close).
I found the fuse listing tucked into the fuse-area of the boot. Certainly the "cigarette-lighter/utility" fuse will be switched (but I think that one was in the boot for whatever reason).
Old Jan 29, 2020 | 11:02 AM
Mercedes GLC 300d
Hi
Yes I plugged into each individual fuse and closed and locked the door each time on all fuses but the camera stays active. If you open the door and unplug the dash cam fuse it powers down in around 20 seconds
Old Jan 29, 2020 | 11:26 AM
aweber1nj's Avatar
2020 GLC, 2022 C
Interesting. I was sure someone reported a few of the fuses on the driver's side were switched.
I ran a cable through the headliner and down the A-pillar to the passenger side fuse box. Finding no switched fuses there, I unscrewed the passenger-side footwell (under the glovebox), and used a wiretap to tap the 12v utility outlet. Ran a wire from there to the fusebox area - which I labeled and basically just used the easy access panel to that location to make my final connections.
My utility outlet is located actually in the passenger footwell - corner of the console, beneath the glovebox. I have the Qi/wireless charging option, and am not sure if the utility outlet is always in that location, or only when you have the wireless charging option.
Good luck. Let us know how you make out.
Old Jan 29, 2020 | 11:53 AM
Mercedes GLC 300d
I will have another look tomorrow the 12V auxiliary power supplies for front and rear are located in the trunk
I will have another look tomorrow but I am sure I tried all those fuses today. The only thing I can think of is that these fuses now supply relays instead of going directly to circuits.
Old Jan 29, 2020 | 01:10 PM
decorily's Avatar
GLC 300d 4matic
No idea about the fuses tbh.... but are you guys talking about drivers side and passenger side from different sides of the Atlantic ?
Are fuses moved from side to side to suit LHD and RHD vehicles?
Old Jan 29, 2020 | 03:01 PM
Mercedes GLC 300d
Yeah the fuses are on different side for RHD & LHD Vehicles
Old Jan 29, 2020 | 03:09 PM
aweber1nj's Avatar
2020 GLC, 2022 C
Yes, I was referring to them as "Drivers Side" and "Passenger Side" purposely, because I am 99% sure they are installed differently for RHD and LHD.
Old Jan 30, 2020 | 03:01 PM
gqboy's Avatar
GLC 300
A search led me to this thread: https://mbworld.org/forums/glc-class...-glc-x253.html Thought it might help.
Old Jan 31, 2020 | 01:17 AM
Mercedes GLC 300d
Hi
problem sorted had to use the utility fuse in the trunk. All of the UK Spec cars do not have any suitable fuses on the drivers side fuse box.
Thanks to everyone on the forum for offering me help and support it’s much appreciated
Old Feb 6, 2020 | 10:47 AM
_MyK_'s Avatar
GLC300 Coupe
Hello
I did use this manual from https://www.drive2.ru/b/512555488303382823/ to install this device on my GLC300 Coupe
You can translate it with google but the main point is on pictures.
Best regards,
Old Feb 6, 2020 | 06:02 PM
DanD.'s Avatar
2018 GLC 4MATIC
Originally Posted by _MyK_
Hello
Best regards,
Did he tap on air bag fuse? There is a red text saying Air bag fuse.
Old Feb 6, 2020 | 07:30 PM
_MyK_'s Avatar
GLC300 Coupe
yes. I did the same way. Just make sure you connect to right side where exit from the fuse. Good luck 🍀
Old Feb 6, 2020 | 11:05 PM
DanD.'s Avatar
2018 GLC 4MATIC
Not sure if its a good idea to put anything on airbag fuse if next to it is the glove box light fuse. Which I picked in my application.
Old Feb 7, 2020 | 07:44 AM
_MyK_'s Avatar
GLC300 Coupe
I have to redo it and use spare fuse 212
just to make sure nothing interfering between each other 😊
thank you for your suggestions 👍🏻
Old Feb 10, 2020 | 12:12 AM
FastE's Avatar
2020 MB-AMG GLC43
For those of you with Augmented reality Nav on your 2020 - you can tap into that camera from factory - just add a USB drive. That's all I am doing.
Old Feb 10, 2020 | 02:13 AM
Tim_P's Avatar
2020 AMG GLC 43
Could you explain this a little more please?
Old Feb 10, 2020 | 03:46 AM
tGs Wraith's Avatar
2020 GLC 300
According to the manual, the AR camera is always active. You can go into the settings and tell it to save its video to USB and it will fill the drive and then start overwriting the oldest footage.
Old Feb 10, 2020 | 04:59 AM
Tim_P's Avatar
2020 AMG GLC 43
Wow, this is a great find - thanks! For anyone wondering, it's on page 364 of the manual, under "Dashcam".
Old Feb 10, 2020 | 08:21 AM
aweber1nj's Avatar
2020 GLC, 2022 C
Just looking at the manual now. That is tremendous. Has anyone checked if this is enabled in USA (it says "selected countries")??? I'm not near my car at the moment and dying to know!
Old Feb 11, 2020 | 01:27 AM
FastE's Avatar
2020 MB-AMG GLC43
It sure looks like it should work. I need to buy a USB-C memory stick. I will try to do that tomorrow and report back.
Old Feb 11, 2020 | 07:45 AM
aweber1nj's Avatar
2020 GLC, 2022 C
I ordered one from Amazon for delivery today. I'm that hopeful. I'll report back when I can test it as well.
UPDATE
This option is nowhere to be found. I am relatively certain my USB drive was recognized by MBUX, but there is no option in the referenced section of the controls, nor anywhere else I searched. It may not be available (yet?) for USA customers. I'm going to email MBUSA and see if they will respond. That's a letdown.
If anyone finds this option, please post back here?
Old Feb 12, 2020 | 07:51 AM
aweber1nj's Avatar
2020 GLC, 2022 C
I received an email back from MBUSA Customer Service (within a few hours, to their credit). It supported my experience with the car, unfortunately:
Thank you for your email to Mercedes-Benz USA.
However, as indicated on page 364 of the vehicle manual, the dashcam feature is not permitted in all countries. As such, this feature is unavailable in the United States.
We apologize for any inconvenience this may cause and appreciate the opportunity to respond.
Old Feb 12, 2020 | 11:39 PM
lay3r3's Avatar
2020 GLC 300, 2019 GLC 300, 2014 e400 Hybrid
NOOOOOOOOOOOOO!!!
i posted they same question previously, why not just leverage the existing cam. Hopefully it can be hacked?
Old Feb 13, 2020 | 07:54 AM
aweber1nj's Avatar
2020 GLC, 2022 C
It's not only "leverage the existing cam", but they already have the software written and tested to do it. They just don't enable it in certain countries.
It's listed in the Software Licenses section of Settings too ("Disabled"). So it requires nothing more than probably an OTA update to enable it.
