Transmission Service Interval
Maintenance schedule booklet was discontinued starting 2017.
I downloaded 2016 GLC schedule and according to it trany and diffs must be serviced
Every 60,000 miles/6 years
Automatic transmission: oil and oil filter change
Transfer case: oil change
I don't see any mention of differential or transfer case for the 274 but have read here that 40,000 miles is the interval.
I also asked my dealer here about the differential. They did some research and basically said not to worry about it.
I had my w213 E300 4Matic done a couple weeks ago- Front diff $76.01, Rear diff $71.73, trans + transfer case $599.10 (they undercharged me 5 quarts of ATF, so figure that would bump the cost up about $100 or so which they absorbed). Paid just under $750 for all 3.
heres my receipt for the w213 with the same trans. You can confirm the parts on your own model as far as compatibility. They quoted me 6 quarts but it was 11 , that was the additional 5 added. I had the diffs serviced too.
They changed you for 10 new screws? wonder what was wrong with the originals... well you did get 5 qt of AT fluid for NC seems reasonable for that service..... not sure what my Stealership would charge I'm way off for diff and AT service... only have 10k on mine ..
my car had under 30k when I did it - 23k roughly. Didn’t know the driving habits of the previous owner while buying cpo so I changed the drivetrain fluids to give myself peace of mind.
