Caliper Colors
Old Jul 21, 2020 | 06:34 PM
  #101
ParjAS's Avatar
19 GLC300 4M (lunar blue/black/black ash aluminum),17 GLE350 4M (selenite grey/ espresso/eucalyptus)
I would say 2000 bucks for amg steering including labor.
Old Jul 21, 2020 | 07:12 PM
  #102
KCSam's Avatar
GLC
I don't like it anywhere near that much.
Old Jul 21, 2020 | 07:25 PM
  #103
ParjAS's Avatar
I think you are done with mods! Somebody else who needs help can use this thread then.
Old Jul 21, 2020 | 07:27 PM
  #104
ParjAS's Avatar
Could you rename the thread to Official GLC Modifications Thread or something like that?
Old Jul 21, 2020 | 07:30 PM
  #105
ParjAS's Avatar
Maybe admin will make it a sticky
Old Jul 21, 2020 | 08:17 PM
  #106
ParjAS's Avatar
Originally Posted by lstupar87
Hey, OP I don't know if this helps but this is my current set-up. Black 2019 GLC with window tint all around and gloss black powder coated 19" AMG wheels. Silver calipers don't look as bad as I thought they might but I'll be getting my calipers powder coated to yellow although I'm still debating on the color. Torn between yellow/blue as I already had red on my previous car and I think I'm over it.
p.s. totally of topic does anyone know if 2020 and 2019 have switchable front grill? I'm looking to have mine replaced by AMG style 2020 all black grill.
I would get the yellow calipers. if I were you. I would also powder coat all the chrome black.
Old Jul 22, 2020 | 09:19 AM
  #107
Brandon C's Avatar
2019 GLC 300 - Coupe
Well, the glue would be inside the new tips and fitting atop the existing tips (I think that's how they attach). If so, then the glue itself wouldn't come into contact with any of the elements. It should stick on there for good. I've never seen anyone who's added these before, so I'd be curious to see how they physically look. I'm afraid some of the chrome may show through on edges.
I have these on my 2019 Coupe. Once the exhaust residue builds up in the pipes - you dont really see the chrome shining through anymore. This pic is when i first put them on and the car was brand new so the chrome is showing a bit.
Old Jul 22, 2020 | 09:23 AM
  #108
KCSam's Avatar
GLC
Thanks for sharing the picture. That doesn't look bad at all. You can't really tell at first glance. How long have you had them on and how have they held up? Did you just use the adhesive that with them, or did you add something additional? I am thinking about adding Gorilla Glue. Is there a noticeable gap or bulky area around the tips once adding?
Old Jul 22, 2020 | 09:56 AM
  #109
Brandon C's Avatar
Ive had them on for just under 2 years now. I originally used the double sided tape that came with it... However...
Although our cars have dual exhaust - I dont know if anyone has noticed but the majority of the exhaust actually comes out of the right pipes - not much from the left.
Because of this - after 2 years - the paint on the cover started to flake off on the right one only. Left one - no problem.
So i pulled it off - sanded it down - painted with Tremclad High Heat Enamel (Gloss Black) - then used some industrial grade metal to metal adhesive (I work for a Machine/Fabrication Shop) - and re-affixed it. No problems since and you can see no difference between the two colors.
Not sure what you mean by gaps?
Old Jul 22, 2020 | 10:05 AM
  #110
KCSam's Avatar
GLC
That sounds like you have a pretty good handle on the adhesive piece. Good to hear. That gives me hope if I go this route.
I had thought that all of the exhaust came from underneath the pipes and nothing actually came from the tips? Maybe it is different with my '20 vs your '19 Coupe.
By "gaps", I mean areas that are exposed along the tips cover. Does it sit flush against current chrome tips?
Old Jul 22, 2020 | 01:07 PM
  #111
ParjAS's Avatar
Oh no. The exhaust actually comes out through those. They are semireal. Look into the exhausts and you will see two wimpy pipes. At least for my19s
Old Jul 22, 2020 | 01:12 PM
  #112
KCSam's Avatar
GLC
I'm pretty sure they are fake on the 20's.
Old Jul 22, 2020 | 01:15 PM
  #113
ParjAS's Avatar
aaaugh mb. You stop makin fake tips or else $!#!##%@
Old Jul 22, 2020 | 01:17 PM
  #114
ParjAS's Avatar
Sorry mercedes. The pipes are real. The tips are fake. If you are so scared, get the chrome done in black.
Old Jul 22, 2020 | 01:21 PM
  #115
ParjAS's Avatar
a beauty, Brandon c
Old Jul 22, 2020 | 01:39 PM
  #116
KCSam's Avatar
GLC
The tips are fake and not functional. The exhaust is dumped out the bottom.
Huh? Scared? I am not scared, just concerned with how the black tips holdup with adhesive, the elements and how they look aesthetically.
Old Jul 22, 2020 | 01:50 PM
  #117
ParjAS's Avatar
oops. I understand your concerns. It worked for Brandon, it should work for you. Aesthetics look fine, I think you'll be all good with those.
Old Jul 22, 2020 | 02:18 PM
  #118
Brandon C's Avatar
There is definitely some exhaust coming out of the tips. Percentage - no clue. But from the paint flaking ive experienced - its mostly out of the right side.
I really wanted the 63s style quad tips - but from all my research and contacting vendors - they wont mount to the standard rear diffuser and you need the whole rear diffuser kit to achieve the look. Didnt want to spend that much.
I then looked at the full housings from the 43 - but opted to go with just the cover plates. As for gaps - you would never know they are cover plates if i didnt tell you. They are almost identical in aesthetics to full 43 housings - at a fraction of the cost.
Old Jul 22, 2020 | 02:48 PM
  #119
KCSam's Avatar
GLC
They must've switched out that from '19 to '20 because my tips are just for appearance. You can stick your hand in and hit the back of them. I read that all of the exhaust is dumped out the bottom and it's really only a one exhaust system. I guess that's good for the corrosion aspect. I won't have to worry about them getting dirty and turning black, but bad for when it comes to blending in the chrome with the tips. It's also good for me that I won't have to worry about paint chipping or the adhesive over heating. If I get them I think I'll do like you and use some metal to metal adhesive - or Gorilla Glue which I already have on hand.
Great to know that they are nearly identical in aesthetics. I'm definitely leaning towards picking these up based off your feedback and positive review.
Old Jul 22, 2020 | 02:49 PM
  #120
ParjAS's Avatar
That's neat. I think the pricing is reasonable also.
Old Jul 22, 2020 | 02:56 PM
  #121
ParjAS's Avatar
Hey Brandon, I would powder coat the trim above taillamps black. I think it would look neat against your white paint. I would also do the mirrors and the door trim and any other exterior chrome bits black, including wheels. It would look awesome!
Old Jul 22, 2020 | 03:05 PM
  #122
ParjAS's Avatar
I have seen similar new tips on eBay for 29 bucks. That's a sharp deal.
Old Jul 22, 2020 | 03:11 PM
  #123
ParjAS's Avatar
that's for 2016-2019 x253. Op has c253 2020. I don't know if this fits on my 20s
Old Jul 22, 2020 | 03:16 PM
  #124
KCSam's Avatar
GLC
I've only found 1 that fits my '20 on eBay and it was $85. I could paint or coat them for less than that.
Old Jul 22, 2020 | 03:19 PM
  #125
ParjAS's Avatar
great!
