Engine off and listen to radio? How?
How do I keep listening to the radio when I'm parked and the engine is off?
Second, depending on your year model, in the centre consol beside the mini wheel there is an M button, or similar marked button that turns on the radio and media function.
All will turn off if battery goes too low.
Another trick is to turn off, open the door to complete car profile, then shut door and press the M button. Radio should work and all other electrical functions like external lights will stop, giving you more battery range.
But I feel your battery needs a good boost from an external charger, driving it will not be sufficient.
Opening the door after turning off kills other electrical drain, then hitting the round symbol turns on the radio .
I would be inclined to agree with Teckno that replacement of one or both batteries might be in order. Go to a business that sells auto parts. They will test and install your batteries for FREE!
