Battery charge indicator?
Old Jan 26, 2022 | 06:16 PM
edpare's Avatar
2020 GLC300 touring version (but I miss my '93 300SE W140 tank)
2021 GLC 300 : analog-style drivers guages has "charge" as a continuation of instantaneous mpg indicator. What is it showing me?
Old Jan 26, 2022 | 07:29 PM
W205C43PFL's Avatar
It just means the alternator is doing its thing, since your vehicle isn't an electric vehicle or hybrid vehicle, it wouldn't have regenerative braking so in your case it is the alternator charging the battery.
Old Jan 30, 2022 | 11:19 AM
edpare's Avatar
Euro part on USA GLC300?
Been watching the behavior of this little guage: it only shows green for a few seconds and only when consumption guage shows "999" mpg. Since I don't have regen and since my alternator is always outputting 14+ V, the system must be checking the status of SOMETHING, perhaps that secret little starting battery I use so often with the default eco stop/start function?
Old Jan 30, 2022 | 11:30 AM
W205C43PFL's Avatar
Make sense that the consumption goes up because if you are stopped, you are not moving and effectively doing 0 miles yet still using fuel.
Old Jan 30, 2022 | 11:57 AM
edpare's Avatar
I didn't explain that well: 999 mpg only occurs while decelerating with foot off the throttle; like going downhill in gear.
Old Jan 30, 2022 | 12:20 PM
W205C43PFL's Avatar
I see, thanks for the follow up. If you haven't notice, putting the vehicle in glide mode/coast mode the green charge will show up as well. The green charge also shows up when the vehicle has completely stopped right?
Old Jan 30, 2022 | 01:40 PM
edpare's Avatar
Putting vehicle in glide/coast mode does not bring up green bar. Only deceleration with zero throttle brings it out and then only briefly.
Old Jan 30, 2022 | 05:50 PM
W205C43PFL's Avatar
Hmmm, I recall that it displays charge and the green bar shows up on my 2017 (sedan) during coasting with the sailing boat icon but I have a C 43 but should be the same, I need to check to see if I remembered it correctly next time I take a drive.
Have you scanned the vehicle for any codes just in case there might be (as in a possibility of) a slight malfunction?
Old Jan 31, 2022 | 06:01 AM
Teckno's Avatar
2016 GLC 250d AMG pack, 2017 GLC Coupe 250d AMG pack , 2002 BMW 330Ci convertible, 2021 BMX X1 sD20i
I think all this is related to the ‘secret battery’ !!
the charge indicator that disappears refers to charging up the AUX Battery that in reality is a small black box hidden under footwell carpet in passenger side that houses a capacitor.
In reality it is a voltage regulator.
These last around 4 to 6 years before needing replacement - the capacitor gives up and needs replacing.
If the car battery degrades or needs charging the stop/start function stops the alternator will never fully charge up the main battery due to AGM construction and higher volts needed.
Regular evening charging of main battery with a smart battery charger, kike CTEK, will lengthen battery, Volt regulator and minimise weird electronic issues that go away when main battery fully charged.
Old Jan 31, 2022 | 10:52 AM
W205C43PFL's Avatar
Thanks for chiming in, OP mentioned that earlier though.
Old Jan 31, 2022 | 11:39 AM
edpare's Avatar
Haven't checked for a code. I don't think anything is wrong; but I do think I discovered one of those "Mercedes Mystery" behaviors that I associate with owning a Merc.
Old Jan 31, 2022 | 01:44 PM
W205C43PFL's Avatar
Yup, exactly. I wouldn't worry about it unless you clearly see something wrong like unable to start a vehicle, CEL, etc. I believe everything is working as intended. I will let you know if I see the same behaviour on my 2017, been getting blizzards lately in my area so the vehicle is taking a break in the garage. That being said, I had a pre-facelift C-Class so it might have changed so it is not exactly oranges to oranges comparison.
Old Feb 4, 2022 | 11:04 AM
W205C43PFL's Avatar
OP, here is an excellent post by superswiss explaining how it all works: https://mbworld.org/forums/s-class-w...ml#post8505582
Old Feb 4, 2022 | 12:27 PM
edpare's Avatar
Yes, but
Great article, thanks for the url. Takes me further on my quest but now I have more questions. "the alternator never actually fully charges them to leave some room for recuperation" Huh? Why not? Why is the period of increased charge relegated to only throttle-off deceleration? And, isn't this behavior EXACTLY how regeneration works?
Old Feb 4, 2022 | 12:42 PM
superswiss's Avatar
2019 C63CS
Yes, it's a mild form of recuperation. Ever since car manufacturers replaced belt driven components in modern cars with electric equivalents such as electric power steering, electric on-demand oil pumps etc. there's increased demand for electric power and also to really reduce fuel consumption, the alternator periodically gets decoupled from the engine and the electrics are powered from the battery. The decoupling reduces drag on the engine, hence saving fuel. So just like in electric cars, it makes sense to recuperate some of the kinetic energy when coasting and put it back into the 12V battery so it can later be used to power these electric components with the alternator decoupled. So when you see that charge indicator, it's just like in an EV. It recuperates some of the energy by increasing the charge to the 12V battery. You won't see the charge indicator when glide mode is active, as then the engine is decoupled from the transmission and idles, so there's no recuperation.
Old Feb 4, 2022 | 12:53 PM
superswiss's Avatar
2019 C63CS
No, the charge green bar doesn't show when you are actually sailing/gliding. To clarify the difference, during the charge phase that's indicated with the green bar, no fuel is being burned, so the engine is kept rotating purely by the momentum of the car. Fuel injection is cut off, so it truly is recuperation as the momentum of the car rotates the engine, which then charges the battery via the alternator. When gliding however, the engine is decoupled from the transmission, and it has to burn fuel in order to keep idling. So gliding is not necessarily more efficient than coasting. Some electric cars therefore also have smart algorithms that decide when gliding is more efficient than recuperating.
Old Feb 4, 2022 | 12:55 PM
edpare's Avatar
Assimilating........
And I wonder how I can access "the workshop menu" with those nifty stats. I can't see my state of charge on mercedes me app.
Old Feb 4, 2022 | 01:04 PM
superswiss's Avatar
2019 C63CS
I posted the instructions in another thread: https://mbworld.org/forums/w213-amg/...ml#post8504964
Old Feb 4, 2022 | 01:17 PM
W205C43PFL's Avatar
Thanks superswiss for chiming in, I learned a lot and I am sure OP did too.
OP, the alternative way is to view the battery stats in Engine data, so that is another option if you want.
Old Jul 22, 2025 | 12:25 AM
W205C43PFL's Avatar
I just realized part of this is a result of battery draining when idling: https://mbworld.org/forums/mercedes-...s-voltage.html @CaliBenzDriver
Old Jul 22, 2025 | 02:33 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
THE BLEEDING EDGE
This power management may now have a chance to be useful on 2021 engines. Put the system through its paces for gentle testing of its fundamentals.
In 2014 ECU voltage remote controlled by Rear-SAM driving ALT output was so buggy ahead of its time it helped the engine run poorly. A great idea poorly freshly integrated.
Hopefully the core timings of the GLC300 engine no longer rely on stable voltage else engine is bound to be moody instead of a smooth torquy Benz engines.
@W205C43PFL can help you troubleshoot the various conditions your chassis may be struggling with.
Old Jul 22, 2025 | 09:01 PM
W205C43PFL's Avatar
I am sure you are better at that : )
Old Jul 22, 2025 | 09:10 PM
Sometimes I can help but I am not familiar with the X253 specifics... The devil is always in the details!
What's involved here?
Old Jul 22, 2025 | 09:30 PM
W205C43PFL's Avatar
I think the main question was answered, being what is the charge bar, the reason I brought you here so you can see this thread and forum member superswiss' reply on the fuel savings and emissions, regulations that implemented resulting in the alternator not charging in certain conditions, running the starter battery to power electronics while the engine is running and more on how this variable "smart" alternator works etc. but I think you know all of this already : ) but just in case...
Old Jul 23, 2025 | 12:29 AM
UNSTABLE VOLTAGE CONTROL
This "smart charging" alternator sounds like a great design. It's only the tip of an iceberg.
When everything is running well, it sounds like more power reclaimed.
Perhaps the X253 chassis handles the low voltage normally without disturbance:
  1. -- Engine throttle should be nimble & strong
  2. -- Tranny shifts should be seemless & instantaneous
Experiment stable voltage for 500.Mi. to see what's missing.
What's involved is the variable voltage in solenoid and coils directly affect results:
  • the ignition sparkplug coils
  • the Throttle-body electric step motor
  • the tranny valve-body shift solenoids
are all directly affected by voltage swings.
This may translates in approximative throttle response and bangy shifts.
