Main Battery Replacement
1) Will removal mess with stored settings? Is this a real concern or just a matter of redoing preferences?
2) Any reason to get an OEM battery from MB, or is a similar battery from a parts store sufficient?
3) I believe it is located under the shroud under the hood on the passenger side. Is that correct?
Thanks!
2) No, you don't have to go to the dealer for a battery. Do the research and get one of the same type, capacity and CCA.
3) Yes, It is located on the passenger side under the shroud in the engine compartment.
You have to have the new battery "coded" after replacing it. This can be done by a number of scan tools, I use a Foxwell NT530.
I have an WIS and there is a step for it but not for this model.
