Bad fuel economy
I just got a 2020 GLC 300 4Matic. I went on a 300 mile trip on comfort mode and cruise control at 75mph and only got 22mpg.
I was wondering if anyone has advice to maximize my fuel efficiency. I know I should’ve been on ECO mode. Is it better to drive manually (without cruise control) in order to benefit from the cylinder deactivation? It doesn’t seem like cylinder deactivation kicks in when cruise control is active.
Appreciate the advice in advance.
Thank you,
Idan Tal
https://www.fuelly.com/car/mercedes-benz/glc300
A few things to do before paying the Dealer to run a set of test >
firstly prior advice here re speed is excellent.
1. Check tire pressures as per fuel filler door for front and rear, at load and ‘high speed’. These are cold psi, not psi after you have driven to fuel station to add air. You could have a garage ‘empty’ the air in your tires and refill with Nitrogen, larger air particle, less heat build up and less loss of air between checks, usually used in race track, but having 2.5 Ton rearing down the highway at 75mph will add heat and stress to the rubber.
2. Increase PSI to about 4PSI higher to give better handling, better braking response and better mileage, some slight decrease in comfort, but worth it.
3. Add an after market bottle of fuel tank and fuel injector cleaner, try a heavy duty one from a reputable shop. May have to repeat with new bottle after 3 or 4 full normal refills. Also what grade of fuel ?, try non eco fuel, use highest Octane, better engine response and fuel usually had additives in fuel to clean your system.
4 after your next oil change, add a bottle of friction modifier, like a ceramic or teflon coating in the engine with all moving parts, helps reduce friction and heat, engine functions better.
5. Certainly try Eco setting next time, then run manual changes, BUT Adaptive cruise control is worth it, less fatigue, less speeding fines and a better experience.
Let us know how you go.
In order to "average" 70 requires mostly 80+ driving, so our trips "average" 60mph / 30 - 32mpg. It still involves some aggressive driving and a radar detector.
Aero does impact the mpg, since averaging 50mpg gets us 32ish.
Interestingly, our '20 GLE450 3.0 six got +2 highway and -2 city.
I believe I get better mileage with My Foot than with Distronic because I can anticipate things like traffic and hills. But I like my Distronic.
My 2018 glc300 4 matic, 40 lbs tire pressure , always gets around, and above 30 mpg on nonstop highway trips driving at 65-75 mph, around 22 in city and averaged 22 mpg over the last 40K, I always stay in Comfort mode above 60mph. Unless you are driving long uphill pulls and/or driving aggressively you should be getting better than 22.
you must still be under warranty. Have your dealer test drive the vehicle.
