Most are aware of the ineffective picture on the reversing camera during low light conditions/night , at least on 2018 and earlier models and not just GLC but pretty much all MB models. Some have said it can be fixed by replacing some of the rear lights with more powerful aftermarket lamps. I have beaten it to death with my MB advisor and they simply wont give you any option. Has anyone fixed the problem on a 2018 or earlier GLC300 and if so please provide details.
mikapen
close
- Join DateOct 2009
- LocationColorado
iTrader Positive Feedback0
iTrader Feedback Score(0)
- Vehicle(s) I drive'21 AMG53 wDPP & ARC, 19 GLC300 - Former-03 C240,2 ML BlueTecs,20 GLE450 E-ABC,15 Cayenne D,17 Macan
Liked:2,187 Times in 1,647 Posts
Can't you just turn up the brightness?
If you mean dial up the brightness of the display , I can , but the picture it self has so many dark and black areas that it just ends up similar to increasing the contrast,and does not light up the dark areas.
The picture is fine during daylight conditions, so the consensus is that the rear of the car is simply not lit up enough for the camera's light sensitivity.
W205C43PFL
close
- Join DateDec 2019
Liked:6,281 Times in 5,451 Posts
Hmmm I wonder if you can swap the licence plate lights with something brighter if that helps? Originally Posted by 2018GLC300
If you mean dial up the brightness of the display , I can , but the picture it self has so many dark and black areas that it just ends up similar to increasing the contrast,and does not light up the dark areas.The picture is fine during daylight conditions, so the consensus is that the rear of the car is simply not lit up enough for the camera's light sensitivity.
Quote:
Yep, did it on my ML and it helped Originally Posted by 2018GLC300
AUXITO Error Free 912 921 T15 LED Bulbs 4000 Lumens/Pair Extremely Bright CSP 9-SMD Plug and Play for Backup Reverse Lights, 6500K White (Pack of 2) https://a.co/d/a5tiJAF
With GLC not ready yet. Here is what I notice, yes camera could be better but sometime it switches into night mode or something and its acceptable, but most of the time its not, I'm not sure how dark it should be before it does goes into night vision mode.
Does turning on the rear fog lights help? Or doesn't your year car have them?
Have you tried replacing the backup bulbs with a high output LED bulb?
Quote:
At night driver behind you might not like it.Originally Posted by W205C43PFL
Why would you be backing up with a driver behind you?
ExploreQuote:
License light is always up, and in dark its very annoying for people who is driving behind you.Originally Posted by GeneS
Quote:
One of the recommendations was to upgrade the license plate lights.Originally Posted by GeneS
The post is about the Backup Reverse Lights. That is not the license plate bulbs
mikapen
close
- Join DateOct 2009
- LocationColorado
Quote:
Another was to use the fog lights. From @GeneS as I recall. 🙂Originally Posted by DanD.
Quote:
License plate lights point down so are unlikely to annoy other drivers but since they point down they are also unlikely to improve rear camera vision. The brighter light might actual impair the camera more.Originally Posted by DanD.
W205C43PFL
close
- Join DateDec 2019
Quote:
Does it blind the rear driver that much? If so, nevermind. Originally Posted by DanD.
W205C43PFL
close
- Join DateDec 2019
Quote:
Was hoping since it is beside the backup camera, the illumination will help, guess not.Originally Posted by GLCDon
