trailer hitch wiring harness for 2022
Has anyone had luck getting an after market trailer hitch installed with the wiring for 4 pin.
Had trailer hitch installed then told the wiring had the wrong plug for the hook up to lights
Received 1,620 Likes
'21 AMG53 wDPP & ARC, 19 GLC300 - Former- 10&14 ML BlueTecs, 20 GLE450 E-ABC, 15 Cayenne D, 17 Macan
I think that would mean that you wouldn't get it any "lights out" or similar warnings in-car, with Stealth Hitch wiring.
If that's the correct harness that the OP has, it should integrate directly with the Can-Bus and provide all those features.
There must be a way.
One that doesn't involve any snipping cutting or tapping - just plugging into the appropriate socket when it's found.
They must bypass the Can-Bus then. Factory wiring is integrated.
the link shold be to the instructions from Steal Hitch.
https://cdn.shopify.com/s/files/1/21...f?v=1698425834
I'd want more secure connections than Scotch-locks and crimp-on power cords, though.
I still don't understand how you would activate things like the blue brake wire, if the car didn't already have a factory hitch.
According to step 25 " The module has an
“input” side that receives
power from the vehicle’s
battery and signals from the
vehicle’s taillights. The
“output” side of the module
delivers this information to
the 7-way plug. The control
module is connected to the
vehicle’s battery and taillight
wiring as outlined in the next steps."
I wonder if there are forums talking about pros and cons.
no, not yet have you?
I bought the TRAILER HITCH CONNECT CONTROL MODULE A1679003402 OEM i believe it should be used as well, not 100% sure though. The black connector goes in this module, however the green one, have no idea. and then the module need to be connected.
