X253 - How many miles do you have?
Old Jan 25, 2024 | 09:55 AM
FreeWoRLD's Avatar
2018 GLC 300 4Matic
MB - How many miles do you have?
Hello fellow MB enthusiasts,
I stumbled upon a similar discussion in another forum and thought it would be a great idea to kickstart something similar right here for our MBs. While forums naturally tend to focus on problems, let's also make sure we mention some positive aspects of our experiences. Though I am not sure how many people keep it to high mileages.
So, I invite you to share some details about your vehicles, including the year and model, as well as any repairs you've had to undertake. It would be cool if we could keep this thread alive and updated throughout the lifespan of our vehicles.
If you would like, use the following format:
  • Year / Model / Current mileage
  • Repair History
Feel free to add any years/models.
Old Jan 25, 2024 | 09:56 AM
FreeWoRLD's Avatar
2018 GLC 300 4Matic
I'll start.
- 2018 GLC300 4matic at 77,800 miles
- Repair history: The only repair was for the P052E PCV valve at around 57k miles. Got the car at 57k miles with no history of any previous repair. I’ll keep posting at every oil change or at least every 10k, and maybe when it dies as I plan to drive it until it does.
Old Jan 25, 2024 | 06:10 PM
ajmtbm's Avatar
Mercedes-Ben GLC300 4Matic
PCV Valve and Sunroof Rails. From what I have read they were not uncommon problems
They were both covered, and luckily I had bought the extended warranty because they happened after 4 years / 50k
Old Jan 26, 2024 | 07:59 AM
dadalook's Avatar
2020 base at 40100
no issue yet
lets keep it this way
Old Jan 26, 2024 | 11:02 AM
Lagtime's Avatar
'17 IS350 F Sport '19 GLC300, '94 Supra
2019 GLC300 bought new in June of that year.
~40k miles.
Flawless to date.
Old Jan 26, 2024 | 11:08 AM
DanD.'s Avatar
2018 GLC 4MATIC
2018 glc300 4matic
~46K miles
No troubles, hope it stays this way.
Old Jan 26, 2024 | 11:12 AM
MB2timer's Avatar
Veteran: Army
Veteran: Navy
SL63
2001 SLK 320 (R170)
170,000 miles
2022 SL 63 (R232)
4,200 miles
If they outlive me, I estimate the SLK won’t get to 200,000 miles, yet still have at least that many miles left in it.
I estimate the SL won’t get to 50,000 miles.
Old Jan 27, 2024 | 10:44 AM
edpare's Avatar
2020 GLC300 touring version (but I miss my '93 300SE W140 tank)
2020 GLC300 RWD 56,653 miles always maintained by Dealer
Zero issues
Old Jan 27, 2024 | 10:19 PM
Ultimatejc's Avatar
2017 GLC300
2017 GLC300 4matic with 13k miles on it.
Bought it 6 months ago and hoping it lasts me a long time.
Old Jan 28, 2024 | 09:00 AM
Kosie's Avatar
Mercedes Benz GLC 250d and GLC 350d AMG-Line
2017 GLC 250d 147 000km
No repairs other than service items.
Old Jan 28, 2024 | 01:56 PM
midesaka's Avatar
2017 E300 Sport, 2017 GLC300 Sport/Night
2017 GLC 300
bought new 2017-01-27
126k miles
HUD replaced at 29k/1.5 years (covered under warranty)
New battery at 79k/5 years
PCV valve assembly replaced at 93k/6 years (retroactively reimbursed under warranty extension)
Otherwise, normal maintenance following schedule
Old Jan 30, 2024 | 03:40 PM
Jetfuture's Avatar
2016 GLC300
2016 GLC300 4Matic with 69,000 miles
P052 Vent Valve replaced at 37,000 under warranty
Replaced Guide Tensioner/belt at 48,000 miles one week before the warranty expired
Fuel leak on a fuel line under car near driver foot area at 49,500
P052 Vent Valve replaced again at 55,000 out of warranty
Have had 3 of the 4 door handle LEDs go out. One repaired under warranty, replaced 2 of the others myself (dealer charges $700 to replace these)
Had one of the sunroof rail clip attachments break at around 60,000 miles. Instead of spending $2500 or so to have dealer replace both roof rails, I ordered a 3-D print part from a guy in France who figured out a way to make a part that you could fit in the rail and twist, thus able to make the repair without removing the headliner and rails (it turned a 6-hour repair into a 5-minute repair and it works)
Just got a reimbursement check for about $1250 or so from our dealer because MB extended vent valve warranty to 15 years and the fuel line warranty was extended to 10 years.
Old Jan 30, 2024 | 09:54 PM
S70Houston's Avatar
2018 GLC300 4Matic; 2008 ML550 4Matic; 2004 C320
2018 GLC300 4Matic
Purchased used on 12/12/2023 with 25,535 miles, One owner vehicle.
Currently at 37,386 miles.
No issues to report so far, other than regular maintenance.
Old Feb 9, 2024 | 11:07 AM
mpalsal's Avatar
When did MBZ extend the vent valve coverage to 15 years?
Does this mean P052 error code is now covered?
Old Feb 9, 2024 | 04:21 PM
Jetfuture's Avatar
2016 GLC300
September 2023 dated letter to registered owners.
Yes, in all likelihood the P052 code would fall under this new warranty extension.
Old Aug 25, 2024 | 09:21 PM
FreeWoRLD's Avatar
2018 GLC 300 4Matic
Originally Posted by FreeWoRLD
I'll start.
87k miles as of today. All good. I’ll update again when I hit 100k.
Old Aug 26, 2024 | 10:19 AM
onodelta's Avatar
Glc300
2016 GLC 300 81k miles, loads of repairs done. Oil solenoid in oil pan, piston 2 cracked. sunroof motor initialization that wasn't stopping at the end stop and just forcefully tried to keep going making a nasty grinding sound, wiper arms absolutely slamming down after they reached the top position, PCV twice, intake manifold vacuum leak, getting a weird noise now that I don't know what it is yet, wiper wiring corroded, another wire corroded that had to do with the starting system and wasn't cranking or starting, steering wheel movement rod broke, fuel line leak underneath making it smell like fuel vapors in it in the winter, mirror welcoming lights, door handle lights, auxiliary battery, charge air cooler pump, loose center screen bolts, sway bar links twice. May be more that I'm not remembering off the top of my head right now.
Old Aug 27, 2024 | 09:45 AM
SkylineEX-S's Avatar
2021 AMG GLC43
2021 AMG GLC43
Just turned over 30000 Km (18600mi)
No problems so far and it is a CPO car so hopefully everything is covered for the next 2 years.
Old Aug 27, 2024 | 09:53 AM
FreeWoRLD's Avatar
2018 GLC 300 4Matic
That’s a lot! Sorry to hear that.
Old Aug 31, 2024 | 04:31 PM
DanD.'s Avatar
2018 GLC 4MATIC
2018 4MATIC with 54K miles,
Nothing to report.
it's a very low milage compare to others.
Old Oct 28, 2024 | 09:09 PM
nguyenmd350slk's Avatar
05-350slk and 08-c350
2022 glc 300...31600 miles
Old Oct 28, 2024 | 09:27 PM
greenbe's Avatar
2016 GLC 300 4MATIC (previously 2004 CLK CAB)
Just got my P052E PCV code on GLC300 2016 ~60K miles.
My trusted independent guy says most likely cracked hose and they are extending the warranty in the US to 150K miles. But when I called the dealer they were non-committal (although did not deny).
We have a letter about the extension on the low pressure fuel hose.
Any experience on this? Was your PCV code fixed under warranty?
Old Nov 3, 2024 | 09:08 AM
Varianti's Avatar
2018 GLC300
2018 AWD 91k miles bought it with 78k
so far only the belt tensioner got squeaky. Easy DIY. And I replaced peeling chrome from the arm rest lock and touch pad bezel.
Old Nov 3, 2024 | 11:01 PM
X253AndBeyond's Avatar
GLC 300 4MATIC AMG Sport / 2024 BMW ALPINA XB7
2016 Mercedes-Benz GLC 300 4MATIC with AMG Sport Package
90k miles
Solid car. Only repairs were a sunroof operation problem 3.5 years ago and a low pressure fuel line leak that was replaced free of charge 1.5 years ago. Truly an amazing vehicle that we can rely on to use for a wide range of duties - daily driving, long highway drives, etc.
Old Nov 4, 2024 | 06:19 PM
NBMBer's Avatar
2018 GLE 400, 2018 GLC 300
2018 GLC 300, 112,000 KM. Partial load ventilation valve recall repair @ 95,000KM. Otherwise drives great so far, no issues.
