2024 GLC300 New Owner Questions
1. Really love the looks and driving - ok thats not a question
2. Dealer told me oil change intervals are 10K miles - do most people go this long? Im thinking 8K would be the max to ensure long life of the drivetrain?
3. Looking at the 10K/20K service packages it seems the main difference is at 20K they recommend changing the brake fluid. Is this really necessary to change the brake fluid every 20K - other cars Ive owned its minimum 5yr/50K with synthetic fluid
4. I havent gotten an exact quote but it seems an oil change runs approx $300 from the dealer - any special reason use the dealer for oil changes or can you go to a quick lube place?
5. Prepaid maintence quote for me was $3K+ for 4yr/40K - is this a good discount on the cost of 4 maintenance service visits?
6. Extended warranty - yes or no? Are there dealers out there who sell factory extended warranties for a discount (Some other brands have a few dealers willing to do this)?
Unfort 10 minutes after we lef the dealer we got a "low tire pressure warning" light on the dash. The pressure was 41 PSI all around and was telling us to check for low tire pressure. I lowered it to 37 PSI which is the recommended value on the fuel filler door to no avail - is this a common problem, or is there an owner way to "reboot" the system?
Thanks in advance!
Thanks in advance!
solution was to go into setting and tell the system what tire pressure is okay. I run my tires at 40 PSI, so I
set the system to that number and no more alerts. 40 PSI is what the dealer originally inflated the tires to.
Any thoughts on the oil and brake fluid change interval?
Thanks in advance!
#3 I not sure on that one. Think 50 is the right answer with synthetic.
#4 My dealer in south Fl gets $600 for A and $1,000 for B. So guess what I had a local shop who specializes in MB and other foreign vehicle do the A service. Total cost including tax.$239.00. My 2023 is leased so I saved the receipt and my contract is not voided.
#5 Not for me. I have used independents for years and the cost of repairs is 1/2 the cost.
#6 I wouldn’t there are generally all sorts of exceptions in the contract.
i run my tires at 38PSI Did the same with my other MBs they were run flats and around 12,000 had to replace. But this car has standard tires and so far at 7,600 show no real wear. But the run flats I could see that they were going to need replacing.
I have one other suggestion for you. Go to YouTube and listen to “Earl on cars” He is a long time car dealer (Toyota but he drives a Tesla). If you want to ask a question tune in on Saturday at 8 am(est). They don’t care what brand you drive all questions get answered.
I love my 2023 GLC300 SUV. Don’t drive to much around 7500/yr and i lease my cars so every 3 yrs I get new, but for many many I owned and put 75,000 before replacing.
i thought that was a good vale for a $55k car with lots of technology. The warranty is from MB and is refundable up to 48 months. Then refund decreases each month as the car ages. But any claim is applied.
a bit on the soft side to favor a better ride. The down side of running tires a bit soft is uneven wear,
as in, the inside and outside edges of the tire will wear down faster than the center section. Just
thinking of the GLK350 that I traded in on my GLC300 and my currently owned M235i proves this
out. After watching the original OEM tires wear the edges faster than the centers, I set the pressures
2 to 3 PSI higher and voila, even wear across the board. I must give thanks to my great high school
auto shop instructor for teaching us students the basics.
Can you give me dealer details please? I have due by Aug 15 to get extended warranty
jjackson@mblouisville.com
Search his name on this forum to see the various favorable posts from those who purchased extended warranties and/or prepaid maintenance plans from him. I bought an extended warranty for the first time ever for our 2020 GLE when we purchased it in June 2019, and it has paid for itself 3x over in the last couple months with replacement of failed evap coil + busted strut. I purchased both the extended warranty (6 yrs/100k) and prepaid service (4 yrs/40k) from Jeff, all done via email - very easy and straightforward.
The oil will be dark after one engine cycle.
On my track car, I used to change the oil before a track day weekend, run maybe 300 miles on track and change the oil afterwards and it's black.
